ooh that sounds too good to be trueHi i had a problem like this a while ago on my NA. i found out it was the piston that goes into the servo sticking! if you look at the servo mounting bracket there is a cut out where you can see the piston, just give it a spray with some lube and that should do the trick!!
iam off to have a look
