Elise Hubs & Speedlines
#81
Posted 21 March 2005 - 12:55 PM
#82
Posted 21 March 2005 - 01:18 PM
#83
Posted 21 March 2005 - 01:42 PM
From what i know:I know taht JT can get me those,
but i have good contacts to a local Lotus Dealer, so i think, i can get them here for a better price (also shipping costs are not good for me, since i´m living in austria)
so would be kind of you, if anyone could give me the Lotus part number.![]()
Maybe via pm?![]()
Michi
Front A117C6002F
Rear A117D6005F.
But check if these numbers are correct
Phil
#84
Posted 21 March 2005 - 01:43 PM
Thanks for the picturesI took a couple of photos of one mounted on the front over the weekend when working on the brakes.Could we get some pictures of the Elise hubs without the wheel and disc ??
#85
Posted 24 March 2005 - 07:42 PM
Rear VX removed per corner 31.95kgs
Lotus replacements 25.15kgs
Weight saving 6.8kgs
Front VX removed per corner 28.35kgs
Lotus replacements 22.99kgs
Weight saving 5.36kgs
So a combined weight saving of 24.32kgs
This brings the system weight down to 885.7kgs and a change in unsprung / sprung weight ratio from 120.6 / 910 = 0.133 to 96.28 / 885.7 = 0.109 which is quite significant. The immediate implication is that only ~80% as much energy will be launched towards the chassis when we hit a bump and cause a wheel to deflect vertically.
This is what it looks like:
I haven't really got it bedded in yet as I've only done about 50 miles. First impressions are very good. There is no issue with offsets and no body binding. The front spacers are unnecessary for clearance but centre the wider tyre around the centre line of the old.
The car feels much lighter on handling and turns in almost too cheerfully. It feels razor sharp on pointing. Most of the mid-range understeer seems to have gone although I haven't yet managed to push it to the limit in a big bend as the road was unknown and the traffic was way too much. However, I haven't managed to get within cooyee of unsettling the A048Rs and I definitely would have been sliding the Bridgestones.
I managed to get quite a bit of heat into the tyres even on the road. I didn't do a controlled temp measurement - I only thought to stick my hand on the rears a couple of minutes after getting home but they felt about 48-50C to me. I had to take the Bridgestones round Bedford to get them to the same temperature. I'll check it with a pyro over the weekend. I don't suppose they will last awfully long at this rate. Watch this space for the first rain report.
The brakes are still bedding. I don't think they are any better than the Pagid 16 groove / SBS pad so far and maybe not as good but will report after another 100 miles. They are well behaved and do not squeak or pull. They work consistently from cold to hot. Maybe the ABS cuts in earlier but its too soon to tell yet. They do not make the wonderful thrumming sound the Pagid 16 groove / SBS combo made. Pity, but the Pagids had to go they weighed about a ton apiece.
It runs absolutely without road noise on a decent surface. Energy transmitted to the chassis is significantly reduced. I almost feel that the handling and grip are so improved that with only the stage 3 tune its now under-powered..... It is suicidally quick - if one is going to insist on driving near the limit then this has raised the limit and the time available to recognise and deal with a cock-up has been reduced. Hrrm. Maybe a Renault 5 would be better after all....
Kind regards - Ian
Edited by cyberman, 24 March 2005 - 07:51 PM.
#86
Posted 24 March 2005 - 07:51 PM
#87
Posted 24 March 2005 - 09:26 PM
#88
Posted 25 March 2005 - 10:04 AM
#89
Posted 25 March 2005 - 07:18 PM
and a front wheel detail:
and for those curious about the cost:
The finish on the Exige wheel is rather matt and I am not sure I wouldn't prefer bright.
Although I wouldn't generally waste paint on a caliper, having opened up the wheel box so much visually it seemed the only thing to do. I am not quite convinced about how its been done (I don't like painting bolts) but it looks OK. Now I only need to work out how to keep the whole wheel arch inner gleaming.
I suppose this pushes me into the next bracket in the "What have you spent on your car" poll.
I thought the lads down at Brook-Kensington did a fair job and they were pretty responsive and helpful. I'll comment further if anything falls off....
As to the Lotus caps, hrrm, no I think I'll keep them. They are *Lotus* wheels. I am told they are a bitch to remove. The little flash of colour is OK. I don't suffer from reverse snobbery. I don't think you can get a Gryphon cap to fit. If it said OZ would I remove it?
Kind regards - Ian
Edited by cyberman, 25 March 2005 - 07:26 PM.
#90
Posted 25 March 2005 - 08:16 PM
#91
Posted 25 March 2005 - 08:37 PM
#92
Posted 25 March 2005 - 11:41 PM
#93
Posted 26 March 2005 - 07:50 AM
#94
Posted 26 March 2005 - 10:54 AM
#95
Posted 26 March 2005 - 11:33 AM
#96
Posted 26 March 2005 - 11:47 AM
Well, mainly because I wasn't offered them. The deal really came together around the parts that Brooke-Kensington had in stock. This made it quick and easy to do. Ordering bits would have delayed it and neither of us wanted that.With the Lotus hubcarriers you´d have saved another unsprung weight.
How much weight would be saved by changing the hub carriers? I might do that later. For now I am pretty pleased with the result.
Kind regards - Ian
#97
Posted 26 March 2005 - 12:08 PM
#98
Posted 26 March 2005 - 04:44 PM
Glad you like it.I just wonder what they would like black.
Black? I just did a quick photoshop job. I have mixed feelings about it. It does look quite eye-catching. But, it also made me think they had been biffed and been given a quick blow over to make them respectable for the weekend.
I'd do it on a track car but probably not on the road. Maybe I'm getting a bit conservative in my dotage.
Ian
#99
Posted 03 April 2005 - 10:15 AM
Edited by cyberman, 03 April 2005 - 10:19 AM.
#100
Posted 03 April 2005 - 06:37 PM
