Na Water Ingress Kit
Posted 18 September 2006 - 08:08 PM
Posted 18 September 2006 - 10:08 PM
Where can I buy a water ingress kit for my NA? Vauxhall?
How much are they approx? Dunno...mine fitted free by VX as a modification due to DIS pack water ingress
Are they easy to fit? Would guess so. Quite a simple mod. May require some drilling of the engine cover
Is the water ingress kit the same as the Turbo? Not sure they did it for the NA. It seemed to be the turbos that had the problem.
Posted 18 September 2006 - 10:38 PM
Vauxhall. part # - V0093183005
£22.
Very.
i think there is only one kit? christurbo did a 'how to' guide on fitting one to the NA
> clicky <
ain't search great?
Posted 01 December 2006 - 07:38 PM
Posted 01 December 2006 - 07:58 PM
stainless steel - can supply you for 30 quid
2 holes at each end in cover.
in pic - left hand side fitted with stainless steel mirror screw into underside of engine cover.
- right hand side , hole drilled horizontally thru bit that surrounds grill , and zip tie pulled tighly thru - very secure.
stopped my misfiring problems on my n/a
