After reading JamesH1983's post asking for suggestions on speakers i felt it was my duty to post last saturdays efforts for all to see.
I bought a JVC KD-AVX2 head unit and some Infinity Kappa's a a couple months back and was dissapointed concidering how the speakers sounded in my old Astra.Put Infinity componant seperates in my old Astra but decided i didnt want to start cutting holes in my VX to install the tweeters, so bought the ones in the clicky above. They are not particularly bass'y but that wasnt my aim, i just want sound quality, so if you want bass probably good to look at pioneers speaker offering.
Anyhow after ordering three boxes of Dynamat Extreme (Only needed two
First thing to do was remove the rear speaker panel, before taking it back in to the wamth of my lounge and getting to work.
Started by removing the tiny amount of accoustic matting Vauxhall had used, they had used some super tacky glue, which clearly goes runny on warm days as the matting had slipped down a few cm in places. No pics of this yet as i hadnt thought of posting it until just after.
Once it was stripped i rolled out one sheet of the Dynamat and peeled back a few inches on one of the long edges. i lined it up with the middle of the top edge above the alarm sensor and carefully worked my way down the panel making sure there was no air bubbles. Its kinda like fitting carpet i guess.
I had to cut it where the panel sepperates and forms the recess for the shelf, i left 3cm to wrap over the top edges shown in the second pic above. Repeat for both sides. There were ideal sized pieces of Dynamat left over from where it extended past each edge of the panel. I used these to fill in the bith i had previously cut around.
After doing all that, which took 3 hours including the hour taken to remove it in the first place all i had to do was cut the speaker and fixing holes back through the matting with a box knife.
Before re assembling my car i made sure i used cable ties to mount the cross overs that came with the speakers out of the way on the roll bar. I had just stuck them tin the speaker void before and they just didnt stop rattling for a moment.
Then i just put it all back together and it was finished, would have preferred to use the original black speaker grills and not the chavtastic ones that came with the speakers but they would have crushed the rubber diaphram on the speakers.
The results were pretty good, before the work my speakers would top out and start fartin, sorry distorting around Vol30 on my head unit, (Max 50). After the actuall volume was about the same on Vol20-25 as on Vol30 before which was a big plus and if i should ever want to turn it up loud, not that i can think of a good reason to drown out the sound of that engine behind me, it will now go up to 40 without too much fuss.
Oh and of course i went for a drive seeing how crispy the day was. Spent a good 3 hours just driving round Dartmoor.
All in all a good day!
Edited by Jive, 09 November 2006 - 09:13 PM.
