Porting And Polishing The Throttle Body
Posted 22 October 2007 - 12:02 PM
Posted 22 October 2007 - 12:29 PM
Posted 22 October 2007 - 01:40 PM
surprising the difference it makes porting the throttle body
Especially since the inside of it was black when i took it off
Couldnt believe the shape as standard, the air going through must be really upset by the huge ridge! When i first started the car , it was idling at 2000rpm before quickly hunting around and settling down to 800 again, so the difference is very obviously definate!
Im no mechanical expert and i thought it was easy, it just takes a steady hand a bit of care. Taking my time saved my one and onyl throttle body, god know what idve done if i cocked it up
Cheers for the how-to Vocky!
Posted 22 October 2007 - 04:46 PM
Posted 22 October 2007 - 06:30 PM
What mm is the throttlebody now in comparison to a standard one?
The key is to port it not to much as otherwise a standard VX will have an ECU error code.
God knows
Was definately worth it and easy too. Seeing as its free, and if you have a careful, patient hand, theres no reason not to do it! I think someone got an ECU error because they tweaked the butterfly too. If you stay away from it and the material it touches you shouldnt get and ECU error.
Posted 22 October 2007 - 06:36 PM
Posted 22 October 2007 - 06:47 PM
Yeah, Markv got an error message as hiw was tweaked alot. I'll be porting my spare TB at the weekend.
Good luck with it
Posted 23 October 2007 - 07:17 AM
Posted 23 October 2007 - 08:25 AM
Posted 23 October 2007 - 10:33 AM
Posted 23 October 2007 - 11:04 AM
Posted 23 October 2007 - 11:14 AM
Posted 23 October 2007 - 11:19 AM
PS Or maybe this:
http://www.z22se.co....light=butterfly
Edited by VIX, 23 October 2007 - 11:21 AM.
Posted 23 October 2007 - 11:25 AM
Please remember this is only a quick sketch and not entirely accurate.
Heres a good how to by Vocky: http://www.z22se.co....ghlight=porting
Edited by andyroo, 23 October 2007 - 11:29 AM.
Posted 23 October 2007 - 12:08 PM
Posted 23 October 2007 - 03:50 PM
Posted 23 October 2007 - 04:05 PM
is it worth to do this mod !Just a small FYI, removing the humps where the throttle plate is in idle position doesn't change the rpm when the car goes to limp mode. Had it happen, no change from what I've seen before, it runs between 1500-2000 rpm.
Oh, and it would be interesting if the error code on my ECU was caused only by the changes to the butterfly valve. That would mean the valve is a HUGE restriction when opened
Mark
Posted 23 October 2007 - 04:18 PM
Mark
If your at that stage it would probably be better to add a ported 68mm tb instead, no? And for that cams, etc are recommended... Yours should be heading in that direction shouldnt it?
Posted 23 October 2007 - 07:13 PM
Wow! Im not one for placebo effect mods, this really did make such a difference! The way the revs raise and fall is so much smoother, the pick up is much more distinct from lower down the rev range where it would struggle before, it just seems to shoot off like a rocket at the slightest tickle of throttle!
So thanks to Vocky and Co for doing the hard work and research, allowing me and other to follow in your footsteps.
Andyroo, do you reckon there is any power increase or is it a pure drivability thing??
Posted 23 October 2007 - 07:33 PM
I couldnt say about power increase without rr'ing it, it probably isnt much! What it does do is allow the engine to rev freely and smoothly and so you can get to the power more quickly. It also means gear changes are smoother, and power and torque seem better at lower revs too where the engine may normally be starved of oxygen. For the price (free!) and the amount of time taken to do it (1-2 hours) its a must-do. Its so easy as well, I was nervous but now I've done it I was wondering what the fuss was!
Its hard to explain the benefits, you'd have to do it and see. To try and put across how much more air the engine gets (the removal of the material allows more air in faster) idle was at 2000rpm until the ecu adjusted it back down to 800rpm. And more air means more fuel which means more power. With the 2.4 manifold which allows more air through the next stage of the intake process, its an ideal mod.
Just do it and stop asking questions!
