Fitting The Mmg Underdrive Pulley
Started by
out on the bike
, Mar 13 2011 09:02 PM
5 replies to this topic
Posted 13 March 2011 - 09:02 PM
Hi after searching for what seemed like ages for the guide I found it hidden in the group buy room so rather than bumping that thread I thought I would start a new one here as this is where I was looking first.All credit gos to pjohn151 who wrote the guide.
original thread with the guide starting near the bottom is here
and a link to the pdf version is here
A big thanks from me to pjohn151 for posting the guide as it was very useful for me today fitting mine.
Posted 13 March 2011 - 09:12 PM
Posted 14 March 2011 - 06:20 PM
The nut on the back of the alternator is a pain I managed to get a socket on it then wedged the socket with a screw driver though I don't think it is 100% tight so when my exhaust arrives and I have the under trays off I will have another go at it and possibly cut an old 17mm spanner down to fit in that tight gap.
Posted 15 March 2011 - 09:01 AM
Glad you found it useful!
That alternator bolt is a real PITA
Posted 01 May 2012 - 09:25 PM
A set of stubby metric spanners is a must for these cars as there is tight or limited access I found the 17mm stubby one fitted perfectly on the back of the alternator.
Posted 04 May 2012 - 09:18 PM
I used an angle grinder to make a really short spanner. The spanner wedges between the nut and the fixing so you can tighten the bolt. I will post it to you if you want
i used this guide last weekend to fit mine it is very good. How did you get on with the nut on the back of the alternator? I ended up removing the alternator so i could get to it and still havent bothered tensioning the belt yet as i really cant be arsed tring to get a socket on it.
