Oil For Running In A Motor
Posted 15 March 2011 - 12:51 PM
Posted 15 March 2011 - 01:00 PM
Posted 15 March 2011 - 01:09 PM
Posted 15 March 2011 - 01:11 PM
Posted 15 March 2011 - 01:12 PM
Edited by slindborg, 15 March 2011 - 01:15 PM.
Posted 15 March 2011 - 01:15 PM
I followed more of that kind of approach on the second engine. The fact it's still going is probably proof that a "harder" run-in works better than pussyfooting around like I did the first time.Rings are bed in within 50miles or so.... MAN UP and do it the hard way treat her mean keep her keen, none of this pussying about letting the rings glaze up a treat!
Posted 15 March 2011 - 01:20 PM
Edited by joe_589, 15 March 2011 - 01:20 PM.
Posted 15 March 2011 - 01:28 PM
Posted 15 March 2011 - 01:36 PM
Oil man is that fully or non syth?
It's a mineral based oil with additives to help it bed in
Posted 15 March 2011 - 09:47 PM
Ooops, I think I gave you the wrong link
This is the one I meant
no problem, makes more sense now
Right then, oil it up and rag the sh** out of it
Sweeeet, that's what you want I want to hear!
cheers guys, helps a lot!
Posted 15 March 2011 - 10:55 PM
Posted 16 March 2011 - 01:02 PM
I was talking to Jez at BoT about this today and he said use mineral oil to run it in and treat it rough!!!!
Works for me!
Posted 16 March 2011 - 05:53 PM
Works for me!
what does? Mineral oil or treating it rough?
Posted 16 March 2011 - 08:56 PM
Posted 16 March 2011 - 08:58 PM
a moderate run up the rev range and lots of snap shut throttle and engine braking on the way down
Exactly what I was told by an engine guy many moons ago.
Posted 17 March 2011 - 08:35 AM
Works for me!
Both (and what Slindborg says) My empirical evidence, 1, the only engine ever to fail on initial running was filled with synthetic, 2, the best engine I ever built was filled with supermarket 20/50 and abused out of the box, but within a 2/3 maximum rev limit.
Posted 17 March 2011 - 06:25 PM
Edited by chris, 17 March 2011 - 06:27 PM.
Posted 19 March 2011 - 06:01 PM
Main point of running in is to full seat the bearings and remove high points of metal finishing around the engine. This generally means the oil needs to be able to suspend metal particles well; the oil needs to have a high dispersant content. All mineral oils are low cost oils with minimised additive treats and therefore low dispersant. Stick with something decent.
Posted 23 February 2018 - 10:44 AM
Thread revival..!
So, reading the above, has anyone taken a different approach (for better or worse) to 'modern' running in process as out lined in the last few posts above?
Trying to summarise the best approach and one free of 'traditional' information which may not be relevant to modern engines.
- Use normal spec engine oil (5W-30 semi-synth GM spec - I'm not convinced manufacturers would specify a different engine oil for new cars for the running in period. I would think this is odd and ripe for causing confusion and potential warranty issues)
- Adjust usage for the first 50-100 miles involving moderately high (but not excessive) variable engine loads and rpm's (many purchasers of new cars will not strictly adhere to these schedule anyway)
- Maybe change the engine oil / filter after 1,000 miles to collect any excess debris created by the initial running in period
