Engine Running Hot?
13 replies to this topic
#1 pdeng8062
pdeng8062
  • 30 posts
  • Interests:Cars of course! (and guitars and beer)
Posted 16 March 2011 - 05:11 PM
Being a newbie to the VX220 scene, I was a bit alarmed when first seeing the coolant temperature reach 106C when in traffic not long after buying it. Then read the manual which said it could go up to 120C so was a bit more relaxed. However, the fans do not appear to kick in until around 105-106C - is this normal? I understand they are controlled through ECU so am thinking of fitting a manual override switch so I can activate them if I get stuck in traffic again (or will try to keep to clear, moorland roads in future!). Are there any guides available as to how to do this? I had a quick look through the forum but nothing jumped out.
#2 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 16 March 2011 - 05:15 PM
scangauge will allow you to do that, also very handy to have
scanguage
Edited by NickB777, 16 March 2011 - 05:17 PM.
#3 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 16 March 2011 - 05:19 PM
Yep that's normal. There is a guid to manually switching the fans on. Its a case of grounding a wire via switch. I will have a hunt..hold on..
edit : here.... Click Me
Edited by LY055SCO, 16 March 2011 - 05:25 PM.
#4 mikeerhymes
mikeerhymes
  • 40 posts
Posted 21 March 2011 - 10:46 PM
I have something strange going on with my coolant temp if anyone has any suggestions..... My vx normal running temp on the move would sit around 83c (it looks like its a cool running stat) and gradually go up if its on the spot like you would expect. It recently started hovering around 98c as the normal running temp, and with the fan constantly on even at normal driving speeds. I figured it must be the thermostat that had got stuck a bit closed which had been stopping the flow causing the higher temp. After changing the thermostat its exactly the same?! Could it be a faulty temp sensor perhaps over reading, is that possible? Has anyone got any ideas what this could be or what I could try? Thanks!!
#5 slindborg
Posted 21 March 2011 - 10:49 PM
Thanks!!
N/A? fans on all the time is an indication that the EGR valve is fcuked. Does it drive badly once warm?
#6 The Batman
Posted 22 March 2011 - 01:03 AM
The fans on constant can be a problem with the air temp sensor in a Na located in the intake pipe. But that wouldn't effect running temperatures and with the fan on constantly I wouldn't imagine you getting to 98' unless stuck in traffic... Are you losing coolant? MartinS was running high temps and the system wasn't pressurising, a way to test this is once the engine is warn carefully and I mean bloody carefully remove the header tank. If you can hear air escaping through the cap then it's pressurising if you don't then you may have a leak somewhere... MartinS was losing pressure but no coolant from the front bleed valve on the rad hose.
#7 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 22 March 2011 - 01:27 AM
scanguage
:yeahthat:
#8 System-G
System-G
  • 333 posts
  • Interests:Trackdays, Racing, Snowboarding, MTB, Computing, Scuba, Gigs etc...
Posted 22 March 2011 - 12:56 PM
Doesn't running an N/A with Scangauge permanently connected cause other minor running issues?
#9 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 22 March 2011 - 01:20 PM
Not on mine.
#10 System-G
System-G
  • 333 posts
Posted 22 March 2011 - 01:35 PM
Goog to know Cliffe thumbsup I found the thread below, but remember reading other similar tales from earlier last year (around the National date)... http://www.vx220.org..._1#entry1083896
#11 simsy
simsy
  • 957 posts
    DOB is not real...
Posted 22 March 2011 - 03:47 PM
I agree with all the above, but remember that vx220 110 deg C is not the rest of the worlds 110 deg C..... I have accurate temp labels on most of my hoses right next to the engine block, and in 3 years they never got above 95 deg c. Stack has shown 112deg c many times......
#12 mikeerhymes
mikeerhymes
  • 40 posts
Posted 22 March 2011 - 07:54 PM
Its a turbo, not losing any coolant and it has plenty in there.
It made quite a lot of air noise when releasing the header tank cap so i can only presume its pressurised?
Its a bit of a strange one really this?!
Anything else i could try?
Thanks!!
#13 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 22 March 2011 - 08:59 PM
Thanks!!
Maybe water pump?
#14 mikeerhymes
mikeerhymes
  • 40 posts
Posted 23 March 2011 - 08:18 PM
Hmmm yeah maybe thanks! I guess its going to be the process of elimination until something works :-(
