Indicator Problem
Posted 26 March 2011 - 06:05 PM
Posted 26 March 2011 - 08:20 PM
Hi All,
have searched and com eup blank so am asking. I have got an issue with the front indicator bulb not working on the near side and when i turn the indicator on left the other two flash really quickly. I have changed the bulb but the new one did the same and on close inspection the bulb wasn't blown in the first place!
I have checked the connections as best i can and they seem fine. any suggestions please?
cheers J
The other bulbs flashing faster is what happens when the bulb is blown, so you know it's blown - it's a legal requirement. As you've checked the bulb I would think here is no voltage to that bulb so the the flasher unit thinks the bulb has blown. You need to check to see if there is voltage at the bulb and check the earth for it also, make your self a test lamp as I doubt you have a multi-meter. I'd check the earth connection first as strange things happen with poor earth connections. I don't know where the earth are but there are wiring diagrams in the TIS, too small to read well on my laptop though.
Posted 26 March 2011 - 08:56 PM
Posted 16 May 2011 - 11:43 AM
Posted 16 May 2011 - 01:10 PM
Posted 16 May 2011 - 01:36 PM
Posted 16 May 2011 - 05:42 PM
Posted 19 May 2011 - 08:20 PM
Posted 19 May 2011 - 08:24 PM
Posted 19 May 2011 - 08:42 PM
Posted 20 May 2011 - 09:27 AM
for earth or if it's working?
all bulbs work but the headlight indicator :/
and fog for that matter, sounds like what the guy up there had!
mine is the rear drivers side cluster. I think it would be easier to remove the entire cluster and check terminal crimps.
