Door Trim Bolts And Screws.
8 replies to this topic
#1 Guest_Loadstar (Guest)
Posted 06 May 2011 - 07:37 AM
I need some bolts/screws missing from the inside parts of my doors (things like the screws that hold the door guards to the frame). These are all missing having taken the door apart. Vauxhall dealer parts department wouldn't even attempt to help me. So what is my best bet for getting some screws that will fit. I dont have *any* of the ones for the door guards so it's not like i can go to B&Q and match the thread. I also need an end bolt to hold the leather door trim bit on the top. Thanks
#2 NickH
NickH
  • 2,171 posts
Posted 06 May 2011 - 08:16 AM
Do you mean you don't have the plastic trim 'screws' that clip in to hold the door panels etc?
If so these are readily available and are listed as psrt number 9197599
EPC link
The screw and washer for the doorpad are also listed as 93178035 (screw) and 9197687 (washer)
Hope this is what you are after.
Nick
#3 Guest_Loadstar (Guest)
Posted 06 May 2011 - 08:18 AM
EPC link
Nick
Thanks - I've got the Christmas Tree clips ok.
It was the selection of screws like the door pad one and the ones holding the door cards to the door frame.
The door pad screw and washer is one of them, thanks...back to vauxhall :(
#4 NickH
NickH
  • 2,171 posts
Posted 06 May 2011 - 08:27 AM
The door cards are held to the door frame with the same plastic clips, there are no screws apart from just inside the door handle surrounds.
#5 Guest_Loadstar (Guest)
Posted 06 May 2011 - 08:28 AM
Yep i know the door cards are. I actually mean the door handle guards, they have two screw holes and look like they screw to the metal. You then fit the black door trim (with door cards attached with plastic bits) over it. I could be wrong though...
#6 Guest_Loadstar (Guest)
Posted 06 May 2011 - 08:37 AM
Yer, looking at the diagram there doesnt seem to be any screw parts for the door handle guard. Strange as im sure there are screw holes that line up with it in the metal door frame behind the black trim assembly. I shall have to improvise. Thanks for the part numbers of the door pad screw thumbsup
Edited by Loadstar, 06 May 2011 - 08:37 AM.
#7 NickH
NickH
  • 2,171 posts
Posted 06 May 2011 - 08:44 AM
You are right, there are 2 screws which hold the surround in place, should be fairly easy to find something to fit
#8 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 06 May 2011 - 01:35 PM
For the inner door handle surround it's just 2 plastic rivet/screws. Can get them from Vauxhall or from Halfords http://www.halfords....tegoryId_165562
Edited by Ouchie, 06 May 2011 - 01:35 PM.
#9 Guest_Loadstar (Guest)
Posted 06 May 2011 - 01:36 PM
Awesome, thanks!
