Coolant And Radiator Fears...
Posted 06 May 2011 - 09:57 PM
Posted 06 May 2011 - 10:16 PM
Posted 07 May 2011 - 07:41 AM
Posted 07 May 2011 - 07:48 AM
Posted 07 May 2011 - 07:50 AM
Posted 07 May 2011 - 08:15 AM
Posted 07 May 2011 - 08:19 AM
Posted 07 May 2011 - 09:19 AM
Posted 07 May 2011 - 03:25 PM
Posted 11 May 2011 - 04:01 PM
Only thing I did notice is that when I stopped after a fairly short drive, but long enough to get engine up to proper temp, I went to look at the engine and noticed that the coolant tank looked like it had coolant bubbling back into it through the top, cabin facing pipe. It was definitely fluid not water, and none seemed to be escaping. Not sure if it's just part of the cooling down or signs of more of a problem.
I don't think that's normal. I've seen that in mine, but only while bleeding the system. Of course at might be the only time I've ever looked at the engine while it's running...
If you're sure there are no leaks, you might try loosening the bleed screws to see if there's air in there. And if the expansion tank looks a bit iffy, then don't wait for the sunshade - just change it. It's a pretty straightforward job.
Posted 12 May 2011 - 07:12 PM
I don't think that's normal. I've seen that in mine, but only while bleeding the system. Of course at might be the only time I've ever looked at the engine while it's running...but I don't think so.
Cheers, in the process of getting the tank now. Can't see any cracks and looks nowhere near as bad as some of the ones I've seen on here. But will definitely get replaced.
Thing is it's running fine, and after a slightly larger amount of water went in, it's been absolutely great, no lights no nothing.
I reckon it's probably ok, but I'm going to look into getting it pressure tested.
Swamped with problems at the mo: engine mounts, MAF, lambdas, coolant tank, leaky seals...
Posted 12 May 2011 - 11:43 PM
Posted 13 May 2011 - 07:20 AM
Those aren't problems - they're characteristics!
Your header tank sounds fine. The return pipe from the turbo runs constantly and squirts coolant across the upper inside of the tank. A failed tank is obvious, the coolant bubbles out of the failed plastic.
Posted 13 May 2011 - 07:25 AM
Posted 15 May 2011 - 09:47 PM
Yeah I know I should expect them! I am happy (and prepared) to spend money on the car, and don't mind these kind of small problems, just kind of thought I would get a longer teething period!
Glad it sounds fine. It's still going though...
If you think you might have a leak get a torch and look in through the front grille and see if there are sighns that coolant has dripped down into this area.
Have done, couldn't see anything. I think it's just using coolant at a fairly normal rate, I was just underestimating the milage I was doing, and was being stingy topping up, as it's still fine.
May think about doing the alloy rad at some point. Roadside catastrophic radiator failure sounds like no fun at all.
