P0300 Misfire Error
Posted 07 May 2011 - 12:08 PM
Posted 07 May 2011 - 12:12 PM
Posted 07 May 2011 - 12:27 PM
Posted 07 May 2011 - 05:09 PM
Posted 07 May 2011 - 05:20 PM
Posted 07 May 2011 - 08:09 PM
Posted 08 May 2011 - 09:23 AM
Posted 12 June 2011 - 02:22 PM
Posted 12 June 2011 - 04:02 PM
Posted 12 June 2011 - 05:26 PM
Does anyone have any suggestions what could be the cause of this intermittent error? I am thinking coil pack or spark plugs, possibly a lambda sensor?
P0300 - Random/Multiple Cylinder Misfire Detected
Calculated load 30.2%
Coolant Temperature 88 degrees
Short term fuel trim bank 1 0%
Long term fuel trim bank 1 0%
Intake manifold pressure 40kPa
Engine Speed 2748rpm
Vehicle Speed 42 km/h
Ignition Timing Advance 16.5 degrees
Intake air temperature 27 degrees
Fuel System 1 status Open Loop (accelerating)
Water getting in between your coil pack and your plugs.
Take coil pack out and spray with wd40.
Works for me.
Posted 12 June 2011 - 05:50 PM
Would the plugs or injectors not produce an error code specific to that cylinder?
Yes. For example.
DTC P0301 Cylinder 1 Misfire Detected
But they only all have to be damp, mine never look wet, think they get damp and corrode a bit which stops the connection, wd40 cleans, drives out moisture and is a good conductor.
Spray the coil pack and plugs up with wd40, if its still missing then your coil pack is fcuked.
Posted 12 June 2011 - 08:09 PM
Posted 13 June 2011 - 07:55 AM
I've replaced the plugs and it's done it again, so it looks like the coil pack is on its way out, it is 10 years old afterall!
Loads of guys will have coil packs laying around I have 3
Posted 13 June 2011 - 08:56 AM
