Spare Ecu And Immobilizer Key Coding
6 replies to this topic
#1 cicastol
cicastol
  • 423 posts
Posted 09 May 2011 - 08:01 AM
Hi,anyone know if it is possible to do a DIY transponder key coding/programming for a second hand ECU taken from another vx220 with interface taken from ebay like the op-com or similar?? I don't want to go to my local vauxhall monkeys dealer to do this job if possible.... Thanks!
#2 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 09 May 2011 - 08:19 AM
ecu
Give this guy a call, he is very helpful and will be able to help you
Edited by NickB777, 09 May 2011 - 08:20 AM.
#3 SteveA
SteveA
  • 9,159 posts
Posted 09 May 2011 - 09:02 AM
I have two ecu's one stage 2 and one standard. You can interchange them without issues as long as you have the ECU, transpnoder ring and transponder chip. If you get another from a VX220 no re-coding/flashing is needed, it will just work. Astra ecu's need flashing with VX220 software to get rid of checks for Traction and Aircon.
#4 smiley
Posted 09 May 2011 - 11:55 AM
How do you remove the handshake between that ecu and the transponder from the other car, without the code?
#5 Exmantaa
Posted 09 May 2011 - 12:44 PM
He means that you don't need to re-flash if you change the ecu + Immo + chip form another VX220...
#6 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 09 May 2011 - 01:39 PM
Thanks!
To DIY you need OP-COM cable and software on a laptop.
See here for a guide.
#7 cicastol
cicastol
  • 423 posts
Posted 09 May 2011 - 07:46 PM
Thanks all!! chinky chinky
