X2 - blue plug
pin 1 = bn/pk (pin 87 of relay K18, +12v for fuel injectors)
pin 2 = wh/bk (instrument - rev counter) + (start relay K24 pin 9)
pin 3 = brn/red (unused plug socket x)
pin 4 = blk/red (unused plug socket x)
pin 5 = gn (+12v FuseBox 7)
pin 6 = blk/red (unused plug socket x)
pin 7 = brn/pink (unused plug socket x)
pin 8 = wh/vt (+12v for relay coil, pin 85 - fuel pump relay K16)
pin 9 = gn/bu (instrument - coolant temp gauge [pulsed signal from ecu])
pin 12 = gn/pk (0v for relay coil, pin 85 - ECU relay K18)
pin 13 = bu/gy (0v for relay coil, pin 85 - radiator fan relay)
X3 - black plug
pin 1 = ye (throttle pedal)
pin 2 = gn (throttle pedal)
pin 3 = bu (throttle pedal)
pin 4 = bk (throttle pedal)
pin 5 = wh (throttle pedal)
pin 6 = bn (throttle pedal)
pin 8 = bn/bu (instrument - oil pressure light)
pin 9 = wh/ye (immobiliser)
pin 10 = bn/bu (instrument - engine management light)
pin 11 = ye/gy (ABS pin 3 - speed signal for engine ecu)
pin 13 = vt [+12v FuseBox 8]
2.2 Engine Loom Blue And Black Plugs
Posted 10 May 2011 - 10:08 AM
Posted 10 May 2011 - 10:19 AM
Posted 10 May 2011 - 11:15 AM
Thanks
I have been trying to source the black plugs seems a bit difficult unless you want 400+
I'm surprised they are only trying to sell you 400.... should be more like 4000
You could try a company called JST as they do small volumes of connectors
Posted 10 May 2011 - 12:18 PM
Posted 11 May 2011 - 09:51 PM
Thanks
http://www.simtekuk....p?p=12&cat=1625
13 way multiconnector. (Send me 2 for the trouble. )
Posted 11 May 2011 - 10:04 PM
Thanks
wish it was that easy it's the 62pin ecu plugs I need
Posted 11 May 2011 - 11:16 PM
Posted 12 May 2011 - 07:30 AM
Posted 12 May 2011 - 08:18 AM
Posted 12 May 2011 - 08:45 AM
Aren't the ecu plugs delphi? Try phoning them, they are rubbish by email.
And buy eleventy billion of them
Posted 12 May 2011 - 05:15 PM
Posted 12 May 2011 - 09:27 PM
Posted 13 May 2011 - 08:24 AM
Posted 13 May 2011 - 08:56 AM
