Fitting Harnesses And Removing Original Seat Belts
Posted 17 May 2011 - 12:50 PM
Posted 17 May 2011 - 12:58 PM
Posted 17 May 2011 - 01:00 PM
Posted 17 May 2011 - 01:03 PM
Posted 17 May 2011 - 01:04 PM
Posted 17 May 2011 - 01:06 PM
Posted 17 May 2011 - 01:34 PM
use a multimeter across the terminals?
possible deployment of the tensioner
Posted 17 May 2011 - 07:10 PM
Posted 17 May 2011 - 07:47 PM
Posted 17 May 2011 - 07:54 PM
Posted 17 May 2011 - 08:40 PM
Posted 17 May 2011 - 10:39 PM
Posted 18 May 2011 - 07:42 AM
I removed the original belts and fitted 2.7 Ohms resistors . It works .Has anyone fitted harness and removed the original belts at all?
I currently have the original belts "plugged in" and rolled up, hidden behind the parcel shelf, but I'd like to remove the completely to save on weight.
However, when removing them, I don't want to have the seat belt warning light on the stack staring me in the face constantly.
As such, has anyone fitted a resistor to the wiring to fool it? If so where / what / how / how much?
Thx in advance for any advice...
Stane
Posted 18 May 2011 - 07:12 PM
Posted 18 May 2011 - 07:14 PM
Make sure you disconnect the battery and discharge any static charge you've built up, before trying to solder in the resistor. Could ruin your day if the explosive charge goes off.I'll let you know how I get on.
Posted 18 May 2011 - 07:40 PM
Should be fine it soldering to the car side rather than the seatbelt side
Posted 10 March 2013 - 03:14 PM
Posted 10 March 2013 - 03:20 PM
Posted 10 March 2013 - 03:35 PM
