New Project
Started by
spelly
, May 17 2011 07:53 PM
10 replies to this topic
Posted 17 May 2011 - 07:53 PM
Finally got round to making a start on my latest project. As you can see, it was looking very sorry for itself!!! After removing the front clam it doesn't look as daunting. Waiting for the new crash box and drivers sill to arrive. Already managed to get a new rear clam for a decent price - couple of weeks should see it nearly completed.
Posted 17 May 2011 - 07:56 PM
Couple on the go at once!!
Good luck, they do look massively daunting with the clams all smashed up.
Posted 17 May 2011 - 08:23 PM
The black one isn't mine - front end damage for a guy at work.
Posted 01 June 2011 - 08:27 PM
Finally had some progress on the project. New crash box is fitted - radiator fitted loosely to make sure fit is OK, need to take it off again to fit new brake pipes. Old sill cut off, new one fitted roughly - needed a LOT of cutting/modifying to make the fit good. Need to remove and paint it, then fit it properly. Getting there slowly!!!!
Posted 08 June 2011 - 12:56 PM
its nice to see these getting back on the road
Posted 10 June 2011 - 10:09 PM
Will be a belter when it's back on the road, I like the look of them alloys mate
Posted 11 June 2011 - 04:10 PM
The wheels are team dynamics - 16 inch on the front and 17's on the rear. One needs a repair, but the other three are mint. Whoever had it before also got the brakes upgraded as it has the larger AP discs fitted with the seperate bells.
Thanks for the comments - encouragement always welcome.
Been busy repairing the black one that you can see in the background - hopefully that one will be finished in a couple of weeks and I can get on with my own one!!!
Posted 31 August 2011 - 06:04 PM
Progress at last! A very close family bereavement has meant no progress on the VX - basically down to lack of motivation and interest! Anyway, decided to spend a few hours on it today. New sill fitted, damaged exhaust replaced and rear clam swapped. Will post some more photos when rear clam is fitted 100% and all gaps are correct.
Posted 02 September 2011 - 09:28 AM
I think this was owned by 'Herman Toothrot' as his was identical to this inc the wheels and brakes and was involved in a bumped a while back.
Posted 03 September 2011 - 03:37 PM
Some photos of the rear clam fitted, doors refitted and the repaired rear wheel - getting there slowly!!!
Posted 05 September 2011 - 07:55 AM
Hi,
yes it was mine Good to see it being repaired.
It has :-
Pro Alloy high volume baffled fuel tank
Courtneys High flow fuel pump
Chris Tullet 4 Branch manifold
Exige ABS ECU
Plans Alloy bells
Alcon Front Discs
Pagid RS4-2 pads all round
Elise parts rear toelink kit
EGR delete
Hanger 111 Harness cut out gromits
Silicon Elise parts coolant hoses up front & Pro alloy rad (That was crushed).
All in all a good buy from the salvage company
Hope you get it back out on track where it was most at home.
Its relacement a mk3 MR2 I blew the engine up on track about a month ago should be getting it back with a 2ZZGE engine on saturday
