http://wiki.answers....r_work_in_a_car
there are a number of types of immobilizers for automotive use. Many new cars come with them installed from the factory, and in those cases the actual electronic control unit for the engine comes from the factory with an immobilizing circuit that will prevent the fuel pump and usually the ignition circuit as well from operating unless a transponder device is within the range of the sensor. These are the best type of immobilizer in terms of safety, because they are not a separate electrical circuit which can be easily tampered with like aftermarket systems.
Is it possible this is the reason for my non-starter? I have no pressure at the fuel rail...
Edited by simonlpearce, 19 May 2011 - 08:19 AM.
