Guides For Inner Drive Shaft Boot Replacement
13 replies to this topic
#1 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 27 May 2011 - 06:00 AM
Discovered that the gearbox side of my nice clean engine bay is now splattered in green slime - nice. Cleaned up the undertrays and got carried away and they now look like polished chrome :lol: Need some guidance on replacement of the boots though, basically 'to-do's' and more more importantly what 'no to-do's'
#2 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 27 May 2011 - 08:34 AM
Chris,
Quite a straight forward job. Are you fitting OE or aftermarket boots? What retainers came with the kit?
Mike
#3 slindborg
Posted 27 May 2011 - 08:52 AM
I wrote a guide a while ago... should be in technical/mods
#4 siztenboots
Posted 27 June 2011 - 08:58 AM
anyone part numbers or equivalent parts for these, can we use Astra 2003 kits?
#5 techieboy
Posted 27 June 2011 - 10:05 AM
No, nothing else from the Vauxhall range fits, as far as I could find. Results of what I did find, were as follows.
Inner CV boot kit (GM Part No: 9197858)
Quinton Hazel replacement, part no: QJB1033
Also used on:
Honda NSX 3.0i VTEC; 3.2i VTEC 06/90-
Kia Carnival 2.5i 24V; 2.9TDi 16V 08/99-10/01
Outer CV boot kit (GM Part No: 9197864)
Quinton Hazel replacement, part no: QJB910
Also used on:-
Mitsubishi Shogun/Pajero 2.5TD; 2.8TD; 3.0i; 3.0i 24V; 3.2DI-D 4x4 01/90-
______________________3.5i 24V; 3.5i GDI 24V 06/94-
Mitsubishi Pajero / Shogun Classic 2.5TD 4x4 07/02-
Mitsubishi Pajero / Shogun Sport 2.5TD 4x4 07/02-
____________________________3.0i 4x4 11/98-
Mitsubishi Space Wagon 2.0TD; 2.0i 08/92-01/00
Mitsubishi L200 2.5TD 4x4 11/01-
Not been able to find any alternative CV joints though.
#6 siztenboots
Posted 27 June 2011 - 10:16 AM
why is that, are the driveshafts funny, the hubs are standard bits. Do they run with a drivers side two piece axle, equal length final driveshaft
#7 techieboy
Posted 27 June 2011 - 10:34 AM
No idea. Never looked at a driveshaft, let alone handle one before this car. I guess it's just a non-standard CV joint that dictates what boot is used. I spent about 6 hours trying to find a matching inner CV joint. Got as far as searching the OEM's (LTN) very limited catalogue based on the model number engraved on the joint itself. Managed to find the specific range the inboard joint comes from but couldn't find an equivalent on another car. Closest I got was something from a Land Rover of all things but I couldn't be sure it was a match.
#8 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 27 June 2011 - 10:49 AM
As far as the boots are concerned, buy OEM as everything else I have tried has been useless.
#9 siztenboots
Posted 27 June 2011 - 11:26 AM
http://www.speedster...haft/index.html
#10 siztenboots
Posted 27 June 2011 - 11:48 AM
Don't know if this helps,
My link
#11 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 28 February 2012 - 01:07 PM
I just called vauxhall they quoted £56.50 :o for a cv kit!!!!
#12 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 28 February 2012 - 01:10 PM
Yup, but you get everything you need and it won't split. Bite the bullet Nick, it is worth it.
#13 NickB787
NickB787
  • 7,813 posts
Posted 28 February 2012 - 02:07 PM
I only thought of doing it as I have the driveshaft out to replace the inner oil seal, more money, BANG
Edited by NickB777, 28 February 2012 - 02:08 PM.
#14 scootz
scootz
  • 19 posts
Posted 08 December 2016 - 07:03 PM
No, nothing else from the Vauxhall range fits, as far as I could find. Results of what I did find, were as follows. Inner CV boot kit (GM Part No: 9197858) Quinton Hazel replacement, part no: QJB1033 Also used on: Honda NSX 3.0i VTEC; 3.2i VTEC 06/90- Kia Carnival 2.5i 24V; 2.9TDi 16V 08/99-10/01 Outer CV boot kit (GM Part No: 9197864) Quinton Hazel replacement, part no: QJB910 Also used on:- Mitsubishi Shogun/Pajero 2.5TD; 2.8TD; 3.0i; 3.0i 24V; 3.2DI-D 4x4 01/90- ______________________3.5i 24V; 3.5i GDI 24V 06/94- Mitsubishi Pajero / Shogun Classic 2.5TD 4x4 07/02- Mitsubishi Pajero / Shogun Sport 2.5TD 4x4 07/02- ____________________________3.0i 4x4 11/98- Mitsubishi Space Wagon 2.0TD; 2.0i 08/92-01/00 Mitsubishi L200 2.5TD 4x4 11/01- Not been able to find any alternative CV joints though.
Sorry for the thread resurrection.
I'm looking for new boots for the Europa and see that the QH ones are a bit cheaper than the GM ones.
Can anyone give an opinion on quality betwen the OE and QH ones?
Cheers
