High Octane - No Need?
Posted 30 May 2011 - 01:56 PM
Posted 30 May 2011 - 01:59 PM
Posted 30 May 2011 - 02:06 PM
Posted 30 May 2011 - 02:32 PM
I am not going to feel any difference if I use it am I?
Just a lighter wallet.
Posted 30 May 2011 - 03:01 PM
Posted 30 May 2011 - 03:07 PM
Posted 30 May 2011 - 04:19 PM
Courtenay warned me not to use less than 97 in my SC.I've been using 99 in my SC NA and I would assume this is best seeing as its mapped?
Posted 30 May 2011 - 04:29 PM
Posted 30 May 2011 - 09:36 PM
Posted 31 May 2011 - 06:58 AM
There is a benefit from running on 99 Ron. The ECU will adapt after a few tanks to the 99 and give you slightly better BHP and MPG. If you go back to 95 it will un-adapt straight away and then take a few tanks to adapt back up to 99 again.
"slightly" reading as very very very marginal
for ANY engine, unless its been calibrated to take advantage of higher ron (and less energetic
The OEM Z22 cal was based on the US where they have some dire low 90's stuff and the 'premium' is 95
Posted 31 May 2011 - 07:19 AM
Posted 31 May 2011 - 08:48 AM
IIRC they use a different rating system for fuel there so a direct comparison is misleading. Our 98 (RON) is approximately equivalent to about 90 (MON) there.
for ANY engine, unless its been calibrated to take advantage of higher ron (and less energetic) fuel then dont bother (even goes for those cheating with FI
The OEM Z22 cal was based on the US where they have some dire low 90's stuff and the 'premium' is 95i very much doubt there would have been much tweak for europes calibration bar the NEDC stuff.
Posted 31 May 2011 - 08:51 AM
Sounds like I have been wasting money!
