Airbag Fault Codes
Posted 05 June 2011 - 07:45 PM
Posted 05 June 2011 - 07:56 PM
I can't remember seeing these fault codes posted before, but finally got round to checking the codes on my OP-COM and I am getting:
"Total number of fault codes: 2
00052 - Control Unit (Squib Code) not Programmed
Present
00037 - Passenger Pretensioner Circuit High Resistance
Not present"
The control unit and airbag are the original items fitted when new, but were stored in a box for yeas before being refitted alst year. I hit a pothole at the end of last summer (when the Nitrons were still on) and pretty sure the airbag light came on soon after.
I only have the passenger seat belt fitted but have a resistor in the driver's side loom to replicate the seat belt pre-tensioner. I had assumed the light was down to me removing and refitting this.
Can the airbag control unit lose the code / link to the airbag through lack of use? I would have thought once the parts were paired together they should be fine.
Have you tried resetting and seeing what comes back?
Posted 05 June 2011 - 09:05 PM
Posted 05 June 2011 - 09:14 PM
Posted 05 June 2011 - 09:17 PM
2.7 Ohm according to this thread, Jimmy.I'm trying to find out which size resister to use for the pre-tensioner circuits. What you used..?
Posted 06 June 2011 - 06:36 PM
Posted 06 June 2011 - 07:14 PM
Posted 06 June 2011 - 08:00 PM
