Boost performance do some good LS1 stuff (www.boostperformance.co.uk I think) and not too dear.
That water pump casting they do for the electric water pump looks like it was made for a vx conversion, fantastic![]()
Sam.
Almost. Ultima IIRC.
Posted 29 June 2011 - 07:09 AM
Sam.
Posted 29 June 2011 - 07:33 AM
The LS1 is 642mm long from bellhousing face to the end of the pulley.
The stock rover v8 is longer than the stock LS1 with the water pumps left on, so like we did with the rover v8 you would have to lose the water pump and run a electric one.
The LS1 is pretty much the same width 520mm(rocker to rocker cover)give or take a few mill (if you move the alternator down to the bottom somewere like we did on the rover v8) and the height of the LS1 is around 125mm less. Im guessing that most of that height is lost from the top with the super low inlet setup, so no boot mods needed.
The main problem is will the starter motor be in the way of the driveshaft as it looks like the LS1 starter motor is alot lower down than the rover v8.
I,ve seen a few pictures of LS1s with thinner harmonic balancer pulleys on which would give you even more room![]()
The stock manifolds are pointing in the right direction too![]()
You would be doing fecking well to get it even close to 900KGs tho with the extra engine weight and with 2 cats on.
Next time i get a chance i,ll measure the rover v8 bellhousing to pulley length.
Sam.
Posted 29 June 2011 - 07:53 AM
Posted 29 June 2011 - 06:03 PM
Posted 29 June 2011 - 11:06 PM
Can i ask what gearbox could possibly be used that could realistically handle the torque ? without solving that question everything else is just a minor detail!
Posted 29 June 2011 - 11:42 PM
Acutually, the 1UZ engines look a t bit too long at 650mm long, before and adaptor plate is added, also pretty wide over the cam covers..
http://c4.ac-images....c92cf5595f7.jpg
Posted 30 June 2011 - 10:00 PM
I think if we ever had a major problem with thr RV8 in future then we,d certainly look at putting in a early stock LS1 before rebuilding another RV8.
Sam.
Posted 03 July 2011 - 06:29 PM
Posted 03 July 2011 - 07:31 PM
Posted 04 July 2011 - 08:34 AM
Posted 04 July 2011 - 09:20 AM
Posted 04 July 2011 - 09:36 AM
Talking of audi V8 I can CONFIRM the RS4 (v8 4.2) engine fits in the back of a vx220 and is sitting there looking all happy for its self
mated to vaux box currently
DG
Posted 04 July 2011 - 10:00 AM
DG
Posted 04 July 2011 - 11:49 AM
Posted 04 July 2011 - 04:59 PM
Posted 04 July 2011 - 05:19 PM
Sounds good to me picture please :-))Talking of audi V8 I can CONFIRM the RS4 (v8 4.2) engine fits in the back of a vx220 and is sitting there looking all happy for its self
DG
0 members, 6 guests, 0 anonymous users
