I have a Spitfire brace bar on my VXT, and would like to fit a 3" exhaust, but I suspect the pipe may touch the bar
Is there any option (2Bular, Tullet, other...) that would allow me to keep the brace bar?
Thanks,
Nicolas
Posted 18 June 2011 - 03:40 PM
Posted 19 June 2011 - 07:05 AM
Posted 19 June 2011 - 09:31 AM
Posted 19 June 2011 - 06:48 PM
But is there enough room in this area to have a different route?If you get a bespoke exhaust made, they can route it any way you like to avoid the brace bar.
Posted 19 June 2011 - 06:49 PM
Thanks, but how did you manage to refit the undertray then?A straight bar would have fouled my 3"2Bular so got PSR Automotive to make this up. Since the photo it's got a beefier centre adjuster and it's been powder coated but it's basically the same.
Posted 20 June 2011 - 08:32 AM
Posted 24 June 2011 - 11:52 AM
Thanks for the explanationApologies, I forgot to say I have an MMG diffuser which uses spacers on the 13mm fixing bolts This plus a single washer gives a JUST enough clearance.
Posted 24 June 2011 - 05:57 PM
Posted 09 February 2019 - 09:59 AM
Posted 09 February 2019 - 10:05 AM
Posted 09 February 2019 - 10:11 AM
Thanks Adam
Posted 10 February 2019 - 09:09 AM
Posted 10 February 2019 - 05:25 PM
I have the one that bolts on the rear of the toe links and its tight. I have about3-4mm of clearance on the exhaust so need to get a drive out at some point. Unfortunately house stuff has taken over car stuff so I've not had chance to check for issues. Fingers crossed it'll be fine though.
Posted 11 February 2019 - 02:04 PM
Hi folks,
Thanks,
Nicolas
If you send me your email address Nicolas on the messenger I can send you the brace fitting guide which covers the options and other brace fittings.
Posted 11 February 2019 - 03:00 PM
