Hi all,
Apologies if this is a basic question but I've searched the forums and can't find a related article - can anyone tell me how to remove the rear speaker panel, also can it be done by just removing the passenger seat and sliding the diver seat forwards (but leaving it bolted to the car)?
Thanks everyone.
Removing Speaker Panel
Started by
Hiro996
, Jun 30 2011 09:02 PM
5 replies to this topic
Posted 30 June 2011 - 09:02 PM
Posted 30 June 2011 - 09:07 PM
Yeah you don't have to take the drivers seat out
It takes a bit of pulling and hoping it doesn't crack!
If it does though I have a mint one with a cargo net for sale
Posted 30 June 2011 - 09:20 PM
Thanks for the reply Joe_589,
How do I actually remove the panel, is it just a number of screws and if so where abouts are they located please?
Hopefully I won't need that panel of yours but it is possible especially since I've never done this before!
Thanks
Posted 30 June 2011 - 09:23 PM
Its on 6 plastic screw fittings, 4 across the back and one each side. You might want to remove the speakers and seatbelt top mount the first time you take it out to make things easier. Mine was a sod the first time as it was stuck down on the shelf part.
Posted 01 July 2011 - 07:28 AM
Thanks for the info FLD and joe_589.
I've read on the forum that there are grommets behind the seatbelts, I assume I need to remove the speaker panel to get to these?
Posted 01 July 2011 - 08:08 AM
To be honest as soon as you get the PAC seat out you will be able to see all the culprit screws
You need to pop the corners roud the fibreglass which can be a worrying moment on first time removal!
