Adjusting The Handbrake Light
10 replies to this topic
#1 FLD
Posted 06 July 2011 - 07:44 AM
Is it straight forward to adjust the handbrake warning light? Mine has started staying on and needs a tweek to put it off. I figure its on a thread or something? Just thought I'd ask before ripping off the console.
#2 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 06 July 2011 - 07:48 AM
Rip off the console, the micro switch needs a tweak that is all, 5 second job.
#3 techieboy
Posted 06 July 2011 - 07:49 AM
It's a microswitch and it just means bending the contact a little. You can just about reach the contact without removing the console.
#4 FLD
Posted 06 July 2011 - 07:59 AM
Superb, thanks guys.
#5 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 06 July 2011 - 01:10 PM
On mine, the light never used to go off. It turned out that the little 'ledge' that the micro switch sits on was slightly bent, and needed adjusting. thumbsup
#6 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 05 August 2018 - 01:36 AM
Digging up a old thread... I've got a slight issue..
The handbrake light is lit when the brake is down.. as the micro switch is pressed..
When its pulled up the light goes off..
Any ideas ?
#7 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 05 August 2018 - 08:03 AM
Any ideas ?
Never seen this switch on mine . Never had the need
But it could be the wrong switch or wired the wrong way how many connections has it got ? A lot of micro switches have three connections 1 common then a normally open and a normally closed ? If it only has two and you have the lights working the wrong way round ie light on when Hand brake is off then try checking it with a multimeter
Edited by christhegasman, 05 August 2018 - 08:06 AM.
#8 vocky
Posted 05 August 2018 - 08:21 AM
as above, you have the wire on the wrong terminal
#9 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 06 August 2018 - 07:31 AM
Just swapped them around on the switch, but its the same.
I also have a c0161 error, so could be related. Is this the switch in the peddle box ?
#10 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 07 August 2018 - 08:57 PM
Fixed that parking brake light... there is a 3rd pin, which is a sod to spot..
. I had it on pins 1&2... it needed to be on pins 1&3 ... 🙈...
I'm really starting to think I shouldn't be a electrician in my next life
#11 aquilaproejct
aquilaproejct
  • 267 posts
Posted 11 April 2020 - 09:23 PM
Hey mate...thread resurrection..... Did this fix c0161 too?
