Loosing Boost, Is It The Actuator? Help!
Posted 29 July 2011 - 01:16 AM
Posted 29 July 2011 - 06:50 AM
If its not he actuator, possibly boost / vacuum soleniod. I have a brand new boost solenoid and used vacuum solenoid if you'd like to try them.Courtenay stage 2, alloy intake pipe, Forge re-circ valve, standard turbo.
I have a boost gauge fitted when accelerating hard the boost reaches 17-18psi then suddenly drops down to zero.
I have changed the two solenoids checked all boost and vacuum pipes but still the same, could it be the actuator? If so how can I check it.
Really need to get this sorted ASAP have a trackday Monday.
Any help will be very much appreciated.![]()
Thanks
Mitch
I am not familiar with testing the actuator but understand there is a way of doing it.
Cheers
Posted 29 July 2011 - 07:15 AM
Posted 29 July 2011 - 08:25 AM
Posted 29 July 2011 - 08:28 AM
Posted 29 July 2011 - 09:41 AM
Sorry mate, just re-read your original post and seen you changed the 2 solenoids.
Thanks
Mitch
Cheers
What spring do you have in your forge?
Posted 29 July 2011 - 10:24 AM
Posted 29 July 2011 - 10:35 AM
Posted 29 July 2011 - 10:38 AM
Posted 29 July 2011 - 11:25 AM
Posted 29 July 2011 - 06:10 PM
Posted 29 July 2011 - 09:24 PM
Glad you made some progress.Have replaced a couple of vacuum hoses that I thought might be the problem and the car is alot better
but not perfect
it is still dumping all it's boost but it's doing it now and again rather than most of the time.
One thing that I noticed while putting everything back together was that the air box was hanging off it's bracket and the pipe that attaches to the air box was hanging off, could this cause boost issues? The car sounds different now this pipe has been re-attached.
Going in the right direction so I'm going to replace all the remaining vacuum hoses tomorrow with silicon hoses and cable tie them on, let's hope that does the trick.
Out of interest, were the 2 solenoids you fitted the exact same part number or the specific front and rear? If so that may contribute to splitting a pipe on the inlet side.
Re: the pipe hanging off the air box... do you mean the pipe that sits in the ear or the AMM to airbox pipe. The one in the ear will have no real impact. If your air box was not connected to the AMM, all manner of sh1t could have been dragged in.
Posted 30 July 2011 - 08:28 AM
Yep the solenoids were replaced like for like, one of the pipe connectors (rubber bit) on the inlet solenoid split as I pulled it off so I'm going to replace all of the vacuum pipes with silicon.
I think this is a job that all turbo owners should think of doing, as some of the connectors on the vacuum pipes are showing signs of age ie. cracking.
