Changing The Vx Lights
Posted 15 August 2011 - 10:20 PM
Posted 15 August 2011 - 10:43 PM
Posted 15 August 2011 - 10:48 PM
Posted 15 August 2011 - 11:29 PM
These 307 aftermarket black ones, with halo led rings look pretty cool though.
Good luck with this.
Edited by smiley, 15 August 2011 - 11:30 PM.
Posted 16 August 2011 - 07:58 AM
Edited by -Dab-of-Oppo-, 16 August 2011 - 07:59 AM.
Posted 16 August 2011 - 09:06 AM
Edited by smiley, 16 August 2011 - 09:06 AM.
Posted 14 September 2011 - 10:37 PM
Posted 15 September 2011 - 09:51 AM
led replacement in original housing.
Something like this for the front would be nice, no need for the plastic lens cover then either.
I don't think there is much mileage in trying to make something from another car fit, if you are molding some sort of adaptor you may as well go the whole way and make the whole thing.
Posted 15 September 2011 - 05:11 PM
Posted 21 August 2015 - 12:39 PM
Posted 21 August 2015 - 01:31 PM
Holy thread resurrection!
I'd thought about moulding the internal bit. Just need a donor set of lamps. I can't see anyone donating those!
Posted 21 August 2015 - 02:14 PM
Both lens are the same matching ones from the lotus...
Using the same vx lens (or replacements) then using the clam mount bracket ... or something along those lines...
Ive ordered a pug 307 light and will cut away as much as possible to see if it has any chance of fitting.
As long as the lights point forward... might work
Posted 21 August 2015 - 02:28 PM
I.e
becoming more and more a kit car
Posted 21 August 2015 - 02:33 PM
Looks gash. Doesn't fit right IMO.
Posted 21 August 2015 - 02:37 PM
That clam has been rebuild around the 307 lights.
Very curious on an attempt to build a spacer between the pug light and an oem clam.
Edited by smiley, 21 August 2015 - 02:38 PM.
Posted 21 August 2015 - 02:39 PM
I'd better hurry up. Can't have cars looking like that.
IMO. The main difference between a VX220 headlight and most headlights is the lack of a robust headlamp carrier system. Normally lights have a rear mounted carrier system and a lens with shroud to make it look good. If you use some metal brackets to mount the lamps at the rear (similar to the Elise approach) then you can have the front section of the headlight bolt in on top of that.
Posted 21 August 2015 - 05:58 PM
How's the progress going as you bought it up rather than me! Agree that looks gash, gaps are even worse than standard VX panel gaps.I'd better hurry up. Can't have cars looking like that.
