Team Dynamic Offsets
5 replies to this topic
#1 Firthy
Firthy
  • 576 posts
Posted 28 August 2011 - 08:26 AM
Hi All,
I started researching on this site looking for the correct offsets for some Team Dynamics 1.2's. However it has left me more confused than when I started... Just after some clarity from people that already have these wheels on a lowered car running R1R's or any semi's the best sizes to have so that the wheels don't rub..
It seem you have 3 common options on the rear but I am unsure which would be best to go for? I can see from previous posts some have gone for 8J et 30 but can anyone confirm if you can run 120 ride height with these without scuffing the outside of the arch and is it worth getting these over a 7.5? Can anyone tell me what the TMS sizes were as a comparison?
Rear wheels 8 x 17 ET30, 110 5 stud PCD and 65.1 Centre Bore.
Rear wheels 7.5 x 17 ET30, 110 5 stud PCD and 65.1 Centre Bore.
Rear wheels 7.5 x 17 ET35, 110 5 stud PCD and 65.1 Centre Bore.
The fronts seem easier, I will be running quite a lot of negative camber on the front so the larger offset should help stop rubbing on the inner arch.
Front wheels 7 x 16 ET20, 110 5 stud PCD and 65.1 Centre Bore.
Sorry so many questions could just do with some clarity as I don't want any tire rubbing!!
Firthy
#2 slindborg
Posted 28 August 2011 - 08:33 AM
Seems most of the Type116 GB rears were 7.5J ET35
#3 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 28 August 2011 - 08:48 AM
You want to really have the rear 10mm higher than the front so i dont know if 110mm on the front might be a little low.
#4 Dave E
Dave E
    I LOVE SNETTERTON
  • 3,116 posts
Posted 28 August 2011 - 09:27 AM
First off the 7 x 16 ET20 fronts will be fine, I'm running a fair bit lower than your talking about and never get any rubbing with 205 x 45 16 R1R's or 195 x 50 16 R888's. Not had any experience of 8J rears, I run 7.5 x 17 ET30. With a decent amount of -ve camber ET35's will rub the inner arch, ET30 are mainly fine for me except the n/s kisses the inner arch but only on track and because I have unusual amount toe in.
#5 Firthy
Firthy
  • 576 posts
Posted 28 August 2011 - 10:22 AM
Perfect thanks to everyone who answered... - VXT'ed that was just the answer I was looking for!!
#6 Paulus H
Paulus H
  • 2,063 posts
Posted 28 August 2011 - 08:19 PM
My Compo spec's... They just work fine. Front wheels X2 MO1670 7x16 offset et20. PCD 5 stud 5x110. C/bore 65.1 black finish + cap Rear wheels X2 MO1783 8x17 offset et35. PCD 5 stud 5x110. C/bore 65.1 black finish + cap
