Denso Alternator
67 replies to this topic
#61 harboged
harboged
  • 392 posts
Posted 11 January 2017 - 01:47 PM
I used as in the pictures. I had to fit a 5p pulley, modify the bottom mounting, machine up a spacer and fab an adjuster strap.
The alternator also needs an additional positive feed to "jolt" it into action.
Dave.
Posted ImagePosted Image
Some questions about wiring. If an alternator should be wired according to the attached picture, does wire #1 correspond to the thin wire that's already there on the z20let's alternator?
If so, then wire #2 needs to be added. Where is a suitable place to take power from? Any 12V that's active when ignition is turned on?
#62 vocky
Posted 11 January 2017 - 02:06 PM
I took mine from an ignition switched supply, which was probably a relay coil
#63 vocky
I had to remake the lower tensioner, due to the original snapping in half :lol:
So made this from an OEM Volvo item;
Edited by vocky, 11 January 2017 - 02:08 PM.
#64 harboged
harboged
  • 392 posts
Posted 11 January 2017 - 08:42 PM
OK, thanks :)
#65 harboged
harboged
  • 392 posts
Posted 02 January 2018 - 11:28 AM
Another question on this mod since I'm about to do it :)
Does anyone know a suitable length for the belt when doing this mod on a Z20LET engine with oem crank pulley?
#66 vocky
Posted 03 January 2018 - 11:46 AM
use a piece of string to measure what length belt is required thumbsup
#67 harboged
harboged
  • 392 posts
Posted 04 January 2018 - 10:41 AM
Yes, will do so. Just wanted to be a bit proactive and possibly gain some time :)
#68 harboged
harboged
  • 392 posts
Posted 31 March 2018 - 05:07 PM
Another question on this mod since I'm about to do it :)   Does anyone know a suitable length for the belt when doing this mod on a Z20LET engine with oem crank pulley?
870mm :)
