Washer Bottle Hose Connection
Posted 30 September 2011 - 08:21 AM
Posted 30 September 2011 - 08:56 AM
Had a simiar issue where the washer hose would blow off the windscreen washers when you used them. I solved this by wrapping the connections with a small tie wrap. The hose goes from the washer pump, up to a T piece under the wiper mechanism, to the washer jets as per drawing below:
The washer pump may be not be working, but obviously you will be able to tell that when you try to operate the windscreen washers
New ones are pretty cheap so may be worth replacing...
Washer pump
Edited by pjohn151, 30 September 2011 - 08:59 AM.
Posted 30 September 2011 - 08:59 AM
Posted 30 September 2011 - 09:11 AM
Many thanks
Posted 30 September 2011 - 11:14 AM
Not sure what you mean about the hose
But as far as the motor goes mine wasn't working
It was the connections on the motor feed were loose
Best way is to stick a multimeter in the plug and get someone to operate the washer switch
No power = switch or fuse or feed cable
Power = motor or a bad connection in the plug
Essentially, the end of the hose had come loose from its mating piece (i.e the T-piece as mentioned in the above thread). You'll have to excise me for being an electrical numpty - Where is the motor feed? Which plug should the multi-meter be hooked up to and where is it?
Cheers!!
Posted 30 September 2011 - 01:02 PM
