Air Box Mods For Vxt
Posted 03 October 2011 - 09:39 PM
Posted 03 October 2011 - 09:53 PM
Posted 03 October 2011 - 09:58 PM
Posted 03 October 2011 - 10:59 PM
Posted 03 October 2011 - 11:25 PM
Dunno, unless we are referring to the same side but there is some confusion. It's definitely the part that faces the air intake/turbo ear that needs the holes!How come cs drilled the top part of my lid?
Posted 03 October 2011 - 11:39 PM
Edited by Nath, 03 October 2011 - 11:42 PM.
Posted 04 October 2011 - 11:25 AM
It sounds quality, especially on the overrun! It doesn't sound super loud from inside but by all reports it's NOISY from outsideIl take a picture in the morning when i have a clean up
Hows the larini system now its all run in?
Louder? Have you had a db reading of it recently?
Im after a back box, just dont know if il get through or started on any track days with it on lol!
Posted 04 October 2011 - 11:41 AM
Posted 04 October 2011 - 11:43 AM
Im after a back box, just dont know if il get through or started on any track days with it on lol!Haven't had a db reading since i've had it but I can't imagine it would be too high for most tracks (would probably be if i'd bought the de-cat as opposed to forking out for the sports cat)
Definetly gets louder once it is coked up a bit. Shouldn't be a problem for trackdays if it's just the back box it's not like on the na vx as the turbo acts as a sound suppressor.
You can here mine in this vid -
http://www.youtube.com/watch?v=eq5gQ6-U1HI&sns=em
Posted 04 October 2011 - 02:03 PM
Do a search on airbox mod, and loads will come up!
The idea is really, is to remove the trumpits inside the box, and cs drilled a small hole on top of the box, for more air to flow in!
It will sound more throatie, like an induction sound really,
Worth doing!!
Leave the trumpet in
Increase the amount of filter that can be used by making loads of holes on the bottom side of the airbox. Leave the paper filter in as aftermarket ones just have bigger holes and let more crap through and gives a microscopic difference in power.
I am going to repeat that you should leave the trumpet in. Removing is detrimental
Posted 05 October 2011 - 11:37 AM
There are two trumpets in the airbox! To which do you refer?I am going to repeat that you should leave the trumpet in. Removing is detrimental
Posted 05 October 2011 - 06:06 PM
Posted 05 October 2011 - 06:20 PM
Leave the top one in (post filter) as it smooths the airflow before going through to the amm.
Posted 05 October 2011 - 09:33 PM
Posted 05 October 2011 - 10:34 PM
Posted 06 October 2011 - 05:01 AM
Posted 06 October 2011 - 07:30 AM
Cons of doing it on the turbo are the stupid dump valve sneezing noise becomes louder, is it just me that thinks it sounds sh**?
Id leave the airbox well alone and get a nice exhaust for impoved sound and performance
Steve
Posted 06 October 2011 - 10:13 AM
Also increases the maximum air flow speed as creates linear airflow. "ripping" the air round a 90 degree sharp angle slows it down and creates turbulance.
Posted 08 October 2011 - 08:09 AM
And people asking "is that a dump valve"?
Steve
I must admit, I don't have a problem with dump valves or the sound they make as long as they are actually doing something useful. Adding one just for the sound is pointless IMO.
Posted 08 October 2011 - 02:06 PM
Edited by Nev, 08 October 2011 - 02:09 PM.
