Seat Grommets
Posted 11 November 2011 - 05:08 PM
Posted 11 November 2011 - 05:12 PM
Posted 11 November 2011 - 05:15 PM
Posted 11 November 2011 - 05:22 PM
so do I need to get extra bolts then to??msar also has the added bolts to make a harness fit properly. there should be a video on the MSAR site explaining things as well, plus search for a guide on seat cut outs.
google search for:
set cut outs site:www.vx220.org.uk
Posted 11 November 2011 - 05:26 PM
Posted 11 November 2011 - 05:31 PM
did you get the msar grommets george as the corbeau ones are loads cheaper but not sure if they work as wellI didnt get any bolts with mine just the grommets, cut the seat out and clip them in place. push harness shoulder straps through hole and attach to bar, job done. Then just sort out the lap straps.
Posted 11 November 2011 - 05:38 PM
Yep.Probably would of bought the cheaper ones if id seen them. Its only a couple of cheap bits of plastic that are sold overprice. Just buy atoms if i were you.
When you do it measure twice cut once and where long sleeves, mask and goggles. I started off with glasses and soon realised i needed goggles, its a horrible job!
Posted 11 November 2011 - 05:54 PM
