Whining Noise From Turbo?
10 replies to this topic
#1 snotvomit
snotvomit
  • 259 posts
  • Interests:Computers, sports cars
Posted 20 November 2011 - 07:45 PM
I was looking at the post by jameslemanski about a sound that might be a leaking manifold (http://www.vx220.org...ine-on-startup/)
I was trying to explain the sound on mine since the remap/precat removal but it's difficult to describe sounds so I have tried to record it. It was raining, so I recorded from inside the car.
There is a high pitched whining sound that changes in pitch with the revs. I though it was some kind of induction noise but after hearing it in the video on the other thread, I am not sure now. I don't know if this was the sound that james was concerned about in his thread.
Here is the recording: http://s105.photobuc...nt=SDV_0009.mp4
Any comments or advice would be most welcome.
I really hope it's not my turbo manifold :(
Is the sound normal?
#2 Nev
Posted 20 November 2011 - 07:54 PM
That certainly sounds like it could be boosted air escapeing. Block the tailpipe up and that will help exacerbate the noise and help you locate it. You may even see/feel where its coming from if you look around when reving fairly hard.Check the mainfold and then all boost pipes to the top hat.
Edited by Nev, 20 November 2011 - 07:55 PM.
#3 snotvomit
snotvomit
  • 259 posts
Posted 20 November 2011 - 08:59 PM
Thanks Nev - I have tried looking for obvious bad connections but I can't find anything. I have a boost gauge but that seems to be reading normal vacuum/boost. It really is quite noticeable and identical to the sound in the other thread. I was hoping someone might have had experience with the same sound.
#4 Nev
Posted 20 November 2011 - 09:32 PM
The Z20LET turbo manifolds are reknown for cracking. If it is that, just chck it in the bin and buy a new Z20LEH turbo off ebay for £400 and replace it. No remap required, so long as you adjust the actuator correctly.
#5 snotvomit
snotvomit
  • 259 posts
Posted 20 November 2011 - 09:48 PM
Yes - if necessary I will get an LEH turbo but I have no idea about fitting it and I'm not sure where to take it in this area for that kind of thing. It's disappointing, though, because my car is a VXR and I know that have some kind of fancy hybrid turbo in them. It would be a shame to bin it but I suppose there will be little option if it's the manifold because it's part of the turbo unit, yes? The car has been remapped, so is it just a matter of making sure that the replacement turbo has the actuator adjusted the same as the turbo that is removed? That will be somewhat of a relief.
#6 siztenboots
Posted 21 November 2011 - 10:00 AM
imho I don't think it sounds like turbo , more like something on the cambelt. you could try unplug each of the two vacuum solenoids and see if you get turbo chatter when rapidly closing throttle.
#7 snotvomit
snotvomit
  • 259 posts
Posted 21 November 2011 - 11:06 AM
Thanks for the replies. I will try the tests suggested here (blocking tailpipe, disconnecting solenoids) before I write the turbo off and order a new one. The car only has 11500 miles on it (5500 of those in the year I have had it) and I had the cambelt done when I got it last year. I didn't do the water pump, though, because I thought that it would be OK with 6000 miles on it. It was the video in the previous thread that made me worry that I might have a cracked manifold bacause I can hear the same whine in the background on that one. Thanks again for the advice.
#8 bigp2
bigp2
  • 290 posts
Posted 22 March 2012 - 08:27 PM
Thread resurrection, I've got a similar (but worse sounding) issue. The whine does seem to be boost dependent, not rev dependent, so I can only assume it's the turbo and not a belt. Doesn't seem to go away when the engine is warm, so not the turbo manifold. Am I right in thinking the actual turbo is buggered? Phil
#9 Nath
Nath
  • 591 posts
Posted 22 March 2012 - 11:03 PM
That sounds shite! Looks of things, you dont have much boost either
#10 chris_uk
Posted 22 March 2012 - 11:30 PM
Awww look... The turbos pretending to be a supercharger :P
#11 JG
JG
  • 13,617 posts
Posted 23 March 2012 - 06:26 AM
Dead turbo I'd suggest
