Turbo Rear Wheel Arch Spat - What Glue To Use?
7 replies to this topic
#1 NDT
NDT
  • 351 posts
Posted 18 January 2012 - 09:15 AM
Found it was hanging off this morning in the school car pack after dropping my daughter off. Looks like the adhesive pad at the top has come loose and two of the three screws had worked loose. No signs of an impact though. Anyone else had this, and what kind of glue works best on the adhesive patch?
#2 fezzasus
Posted 18 January 2012 - 09:29 AM
Clean the area with meths and use araldite as it has some flex to it - superglue might give you a better bond but it's brittle and could cause it to crack
#3 NDT
NDT
  • 351 posts
Posted 18 January 2012 - 09:49 AM
Thanks Fezzasus. Rather than trying to peel off the original adhesive pad and replace it I'll use araldite on one side only. N
#4 vocky
Posted 18 January 2012 - 10:25 AM
the spats are held on with three screws, the sticky pad was most likely added at some point to help hold it on
#5 Wolfstone
Wolfstone
  • 12,984 posts
Posted 18 January 2012 - 12:48 PM
:yeahthat:
I've just replaced mine that were looking a bit tired with some brilliant condition second hand ones from ElizP and there were no sticky pads when I removed mine.
#6 NDT
NDT
  • 351 posts
Posted 18 January 2012 - 04:06 PM
Thanks Vocky.
Fiddling around with the pad is a bit of a bodge but I've replaced the screws too.
Nick
#7 Branagorn
Branagorn
  • 90 posts
  • Interests:I like bikes too
Posted 28 March 2017 - 02:23 PM
Having the same issue.  Tried using tigerseal.  Didnt work, but I hadnt cleaned the area.  Then found this thread for advice.
Try again after meths cleaning, or go for a different bonding substance, i.e araldite as suggested here?  Just wondering if the tigerseal should work, or I need to make a trip to the shops.
#8 turbo boy
turbo boy
  • 1,161 posts
  • Interests:Cars, fitness, fishing, sports
Posted 28 March 2017 - 03:53 PM
I used tiger glue in combination with the screws. No issues. 👍
