Sc Owners - Check Your Charge-Cooler Coolant!
14 replies to this topic
#1 VIX
VIX
  • 9,497 posts
Posted 28 January 2012 - 02:55 PM
Sometime before Christmas I noticed that the car was pumping out more than the usual cloud of white smoke/steam on start up - more than could be put down to condensation in the exhaust alone. The first time it happened it was so thick that the cars behind disappeared completely! :o I'd not lost any engine coolant so was able to discount HGF. On checking the charge-cooler header tank I found the level was a good few inches down. Of course that's the one thing I no longer routinely check as there never seemed to be any loss. To cut a long story short, it turned out to be the laminova core seals, a couple of which had hardened and flattened. A new set of seals and some sealant later and all seems to be well. It's more than a bit annoying that the seals have failed so soon. The manifold was a new unit, installed less than 4 years ago and has probably covered under 20k since. The moral is to keep an eye on your charge-cooler coolant levels as it's not the sealed unit I thought it was! Thanks go to - well you know who you are! thumbsup Imnotworthy
#2 JG
JG
  • 13,617 posts
Posted 28 January 2012 - 03:27 PM
thanks for the tip :)
#3 techieboy
Posted 28 January 2012 - 03:37 PM
Water injection. Kept your intake temps nice and low. :lol: It's probably what the rest of us with silly pulleys need to do. :wacko:
#4 VIX
VIX
  • 9,497 posts
Posted 28 January 2012 - 03:48 PM
:lol: I'd be interested to see some with and without chargecooler metrics to see what difference they make with "only" 250 bhp on tap. :unsure:
#5 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 28 January 2012 - 03:52 PM
Thanks for the tip, where did you order replacement seals from? might like to keep a set handy
#6 VIX
VIX
  • 9,497 posts
Posted 28 January 2012 - 04:16 PM
You have pm Nick.
#7 Denthrax
Denthrax
  • 272 posts
Posted 28 January 2012 - 05:28 PM
Yes, please share. As mine weren't in the best condition when I put the thing together.
#8 VIX
VIX
  • 9,497 posts
Posted 28 January 2012 - 05:41 PM
I'll check where they came from and post. thumbsup
#9 vocky
Posted 28 January 2012 - 05:59 PM
Sutol posted this info in another thread
Supaseal ltd
O rings size 29.75 x 3.53 nitrile BS217
http://supaseal.co.uk/kits.htm#o-rings
Edited by vocky, 28 January 2012 - 06:00 PM.
#10 Hark
Hark
  • 3,443 posts
Posted 28 January 2012 - 06:19 PM
I have the Alumunium header tank so you can't look see how much is in. Should it be roughly half full??
#11 The Batman
Posted 28 January 2012 - 06:20 PM
i fill it so its just under the return flow draw a line using a sharpie on the inside of the tank to mark where the level is
#12 NickB787
NickB787
  • 7,813 posts
Posted 28 January 2012 - 07:14 PM
cheers Vocky, just in case.
#13 VIX
VIX
  • 9,497 posts
Posted 28 January 2012 - 07:30 PM
Torch and a ruler! ;)
#14 Hark
Hark
  • 3,443 posts
Posted 29 January 2012 - 12:37 PM
Sorry Vix I wasn't trying to sound as dim as I did. What I meant was there are obviously no markings like on the radiator header tank, and as I bought the car with the Supercharger already fitted, I wanted to know how full it should be. I'll go with Joes suggestion of below the return flow.
#15 VIX
VIX
  • 9,497 posts
Posted 29 January 2012 - 05:18 PM
;) I think I'm about 80mm below the extreme top of the filler cap - about 25mm below the return flow. thumbsup
