Seat Belt "locked"...
11 replies to this topic
#1 kcabneits
kcabneits
  • 105 posts
Posted 08 February 2012 - 09:15 AM
I ran into an issue yesterday, when I started to put the interior back together.
I've removed the seat belt tensioner/roll on the drivers side (LHD) to get to the fuel pump.
When I was on my way to put it back, I realized that the belt had rolled all the way back in and "locked"... :(
I've can see the mechanism that stops the belt from rolling out, but I can't find out how to release it.
Does anyone have a clue how to do this?
All the way in:
Locking mechanism:
#2 CocoPops
CocoPops
  • 17,182 posts
Posted 08 February 2012 - 09:26 AM
The seat belt needs to be oriented the right way up, then GENTLY rock the belt in and out. IT's not permantely locked, it's the "Inertia" lock that holds the seatbelt in place in case of sudden motion/movement. Perfectly normal.
#3 kcabneits
kcabneits
  • 105 posts
Posted 08 February 2012 - 09:47 AM
Aha, so I just did it the wrong way then! :) I'll give it a try when I get home! Thanks!
#4 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 08 February 2012 - 12:32 PM
Perfectly normal.
:yeahthat:
Once locked you need to feed in a bit in order to get it to come back out again. If you have somehow managed to lock it with the buckle right up tight against the mechanism you may have a bit of a problem. If this is the case try and push the coil of belt round with your fingers a bit then jiggle the strap but don't be tempted to open the metal cage up at all as there is some serious tension waiting to be released in there!
#5 kcabneits
kcabneits
  • 105 posts
Posted 08 February 2012 - 12:53 PM
Perfectly normal.
:yeahthat:
Yep, the buckle is all the way against the mechanism...
That's the biggest issue, since I'll need to feed in a part of it.
I'll probably have a "small" challange to get it right. ;)
#6 kcabneits
kcabneits
  • 105 posts
Posted 08 February 2012 - 05:53 PM
Haha, now I feel like a complete noob!! :P The right way up, and it was as stuck as a hot knife in a bucket of butter...! :D At this moment I'm amazed that I was able to change the fuel tank... :lol:
#7 CocoPops
CocoPops
  • 17,182 posts
Posted 08 February 2012 - 05:55 PM
thumbsup ;)
#8 rueda
rueda
  • 124 posts
Posted 10 August 2016 - 10:59 AM
I've the same problem ! But now, the belt is completely at the end of the stroke and I can't feedback the belt at all.
Is there anyone who know how to release the locking mechanism ?
#9 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 10 August 2016 - 01:10 PM
You have to hold it the right way up. Any other way up and it locks.
#10 rueda
rueda
  • 124 posts
Posted 10 August 2016 - 01:36 PM
That's what I tried before, but now, I can't hold it anymore as I'm in the end of the stroke !
#11 rueda
rueda
  • 124 posts
Posted 10 August 2016 - 05:46 PM
Ok, thanks for help. I read too fast and as I'm french, misunderstood first.
Right way up, it unlock the mecanism, but I was so blocked at the end of the stroke (the belt was touching the frame of the tensionner) that I Had no choice to try to unlock it manually. Now it works, but it never lock ! In fact, I've broken it ! :(
#12 rueda
rueda
  • 124 posts
Posted 12 August 2016 - 04:47 PM
I'm looking for a another one.
Anyone knows if a seatbelt assembly on an other car is the same than the VX one ? I've hear about alfa 147 ?
