Airbag Removal, Resistor Placement...
Started by
kcabneits
, Mar 08 2012 07:49 AM
4 replies to this topic
Posted 08 March 2012 - 07:49 AM
I know that there's lots of post about the airbag removal, but I can't find an answer for this specific question.
I'm changing to an aftermarket steeringwheel.
I've removed the airbag and the original wheel.
But I wonder if I can "install" the resistor directly in the airbag connector (fixing it with some shrink hose or something)?
When I tried to carefully look inside the connector (just in one corner) I noticed that it looked like there's a coil or something in it...?
I guess that I should install it in the connector, since the resistor should cheat the ECU that the airbag still is in place (and thereby need everything with the cables/connector to be as is)...
I just want to save myself a trip and the cost to have to go to Opel to get rid of the airbag warning light.
I don't really want to cut off the connector in case I would like to go back to the original wheel again...
//T
Posted 09 March 2012 - 10:59 AM
Nobody that got an answer for this??
Posted 09 March 2012 - 11:04 AM
It's easy to install a resistor. Just measure the resistance of the airbag you have taken out with a meter, and place a 1+ watt resistor in its place.
Posted 09 March 2012 - 11:12 AM
I got the 2,7 Ohm resistor, I just wasn't sure if I should "install" it in the blue/yellow connector or if I had to cut the connector and solder the resistor directly on the cables.
But I just insert it in the connector and try to get it fixed there somehow.
Thanks for the reply!
//T
Posted 09 March 2012 - 11:18 AM
i cut my wires and soldered it on with, heat srunk it all properly, either way will produce the same result
