Edited by chamy, 13 March 2012 - 07:01 PM.
Minor Paint Blister Repair
Posted 13 March 2012 - 07:01 PM
Posted 13 March 2012 - 07:30 PM
Posted 13 March 2012 - 07:33 PM
Posted 13 March 2012 - 07:54 PM
Posted 13 March 2012 - 08:08 PM
As ever with an osmosis repair.
Grind out deeper, steam clean, dry, wipe with acetone, fill with high grade grp filler (not p38!!!!), epoxy resinous gel coat to seal then usual prep for paint.
Thanks for that, you seem to know your stuff.
Few q's if you dont mind
Would you suggest to use something like plastic padding as the grp filler? (Ive heard p38 is too brittle)
When you say the usual prep, does that include priming? Or would you put the base over the gel coat directly?
Posted 13 March 2012 - 08:13 PM
Posted 13 March 2012 - 08:18 PM
Posted 13 March 2012 - 08:38 PM
Not osmosisAs ever with an osmosis repair.
But the rest is largely correct. The drying is key. If you don't properly dry / bake the GRP then you are likely to suffer from blistering again in the future.
Posted 13 March 2012 - 08:39 PM
Epoxy resin is fine as a gel coat. Readily and cheaply available.Never done anything with gel-coat before but you could use an epoxy primer such as Lechlar which contains dangerous isocyanates or Jotamastic 80 which is isocyanate free before HB and COB.
Posted 13 March 2012 - 08:50 PM
Posted 13 March 2012 - 08:56 PM
Not osmosis
Some of it is osmosis, and it is the movement if water in the poorly made clams making it to the surface lol.
Wests stuff is great, pricey but you get what you pay for.
Posted 13 March 2012 - 09:01 PM
