A number of known and trusted VX220.org members have reported Edwards to the moderating team concerning the way he does business.
Where we cannot comment on each instance individually, we can comment that the independant complaints recieved were all of a similar nature.
It is the belief of the Moderating team that any individual considering doing business with Edwards should do with caution.
Regards,
The Moderating Team
I am breaking a big spec mk4 astra coupe turbo, the engine and running gear, brakes etc may be of interest to some members here?
Z20let engine fully rebuilt with mahle main bearings, oil squirters, wossner pistons, steel rods, ARP 2000 bolts, rebore and honed block, polished crank, balance shaft deletion kit- £2000
6 speed m32 vxr gearbox with Quaiffe LSD - £1200 (also have standard diff here)
Drive shafts- £200 pair or £120 each
standard z20let shafts- £60 each or £100 pair.
oil catch tank and pipes/bracket- £20
tubular manifold and gt2871R turbo- £1500
Alcon 4pot Brake kit as new from thorney motorsport with receipt- £1050
3" catback cobra exhaust system- £350
3" downpipe section with sports cat- £500 (front courtenay sport)
vxr AFM- £80
z20let AFM- £35
powdercoated rocker cover in black- £40
OPC coilpack cover- £13
coilpack- £35
polished oil pipe (redirected for the manifold) £25
inlet manifold- £30
blue tophat- £25
throttle bodie- £30
650cc injectors- £250
z20let injectors and rail- £30
JDM sport FMIC kit with pipes from tophat to turbo- £200
alloy radiator- £100
alternator- £25
aircon pump- £20
cambelt cover- £10
cdti airbox and pipework- £100
lower front gearbo mount with powerflex rubber- £25
engine wiring loom- £70
dash loom- £50
Baileys dump valve- £50
Strut brace- £40
Ecu, chip and pickup ring mapped to 380bhp- £250
uprated fuel pump- £50
standard fuel pump- £20
standard flywheel- £20
brand new helix clutch new and unfitted- £80
standard front calipers- £30 each
standard intercooler- £20
front hubs- £35 each
rear hubs- £25 each
rear calipers- £20 each
standard suspension springs and shocks- £40
Interior:
Seats front and rear complete- £50
doorcards with blue trim- £50
A, B and C pillar trims in blue- £50
center console with some marks- £20
MFD with a couple of dead pixels- £25
clocks- £25
steering wheel- £60
heater rings- £15
throttle pedal- £20
Silver seatbelt set- £30
turbo floor mats- £25
OPC vxr 6speed gearknob- OFFERS!
VXR gear selector unit- £50
VXR gear cables- £40
passenger rear light- £10
sharkeye headlights with HID kit- £120
coolant bottle- £5
battery tray- £5
coolant ecu- £20
18" alloy wheels with new tyres- £500
wiper motor- £20
heater blower unit- £20
irmscher door pins- £10
fog lights- £15 each
This is the list of items which i have for sale in the for sale thread on the astra owners club, i know many items will be of no use to alot of you members but i thought i would add it to this forum as i used to own a few vxt's :-)
i also have many mk4 astra turbo parts for sale on my website http://www.torquemotors.co.uk
