Sc & Fault Code - P1171
Posted 22 May 2012 - 09:52 PM
Not really sure what the issue is to be fair, or if their related but anyway....
Just to give a bit of background, SC Stage 2, Standard Manifold, VSE and Base Map. Ran like that for about 150miles then removed pre-cat. ...
Drilled out pre-cat, took it for a little spin and it sounded a bit different. Was going alright and then it suddenly almost I would say farted, bogged now and then started accelerating. Almost something similar to what Bargi is describing here... Anyway. Stopped car, started up again, and it did this sort of hesitation a few more times and then progressively less and less to barely at all now.
http://www.vx220.org...ing-under-load/
The other issue, possibly related or if its even a issue but couple of evenings ago driving along, maybe done 15 miles and noticed 91c on the display but the fan was on in the front, odd as I thought as it never ever used to come on unless manually done with the scangauge. Anyway, didn't think to much of it, no EML light and fan wasn't on when car started later on.
Today, driving along and car didn't feel as pokey as it has done, maybe mental thing. Randomly checked scangauge and came up with P1171.
P1171 - Fuel System Lean During Acceleration
Unfortunately on SC'd cars I can't seem to find to much information about this fault.
http://www.vx220.org...saga-continues/
Anyway, I've cleared the code, went out for a quick spin and the code hasn't returned and it feels silly quick again. If the fault doesn't flash back up does that mean its sorted itself, or is investigation required further? - I guess first port of call would be lambda sensors?
Posted 23 May 2012 - 07:56 AM
Edited by Goosenka, 23 May 2012 - 08:07 AM.
Posted 23 May 2012 - 08:02 AM
Edited by smiley, 23 May 2012 - 08:05 AM.
Posted 23 May 2012 - 08:06 AM
Posted 23 May 2012 - 08:15 AM
Posted 23 May 2012 - 08:21 AM
Edited by NickB777, 23 May 2012 - 08:31 AM.
Posted 23 May 2012 - 08:29 AM
Posted 23 May 2012 - 08:32 AM
Posted 23 May 2012 - 08:42 AM
Interesting, that would explain why the plug is a slightly different colour to the restYep, base map is a bit lean at the top end, but i suspect you went round a corner a bit quick.
or you have the slight issue with cyl4, wich also goes lean on some builds. Why? no one really knows as far as i can make out. Some say valve springs, others fuel pressure, the list goes on and on.
Posted 23 May 2012 - 08:44 AM
Posted 23 May 2012 - 08:45 AM
Posted 23 May 2012 - 08:49 AM
yepis cyl4 the one with the EGR casting in the block
Posted 23 May 2012 - 09:22 AM
When cold I also find that the car has no drive so to speak when accelerating. Not hard accel but just standard if you like. It is almost like its blocked or really holding back. It almost feels like its a bit jerky.
Once warm it's fine. I mentioned this in my thread a while back and the comments where that on cold the sc cars can be a bit like that. I have taken to leaving the car idling for 2 minutes or so before offski.
I have a very similar set up Vse, stage 2 sc. not sure you mentioned whether this was after start up or not?
I don't however have any codes but my fuelling contrary to a number of others is terrible on fuel.
Edit to add - when are you getting it mapped? Personally speaking I would not keep it running on the base map for too long and you might find that it clears the issue.
Seems to only really be an issue with the holding back when cold / warming up. Every time from cold, without fail its been reluctant to accelerate at low speeds, but as you said after a while it disappears and everythings good.
It seems to be doing ok on fuel, not tooo dissimilar from what I had with a standard NA.
Its booked in for 12th June for mapping...
Edited by tommobot, 23 May 2012 - 09:22 AM.
Posted 23 May 2012 - 09:33 AM
Posted 13 June 2012 - 09:05 PM
