Cycling Abs When Bleeding Brakes, With Scan Tool
Posted 01 June 2012 - 02:03 PM
Posted 01 June 2012 - 02:10 PM
Posted 01 June 2012 - 02:14 PM
Posted 01 June 2012 - 02:16 PM
Posted 01 June 2012 - 02:17 PM
Ah, right. Thought it might have been to do with the bleeding proceedure. Do you know if Murray Motors Connect up the ABS modual while bleeding the brakes?They seems to work now, I managed to get ABS pedal today as it is turned back on but that I can cope with. My fluid was just over a year (14 months) old and had gone off so it was not due to a fluid change that had not cycled the ABS.
Posted 01 June 2012 - 02:19 PM
No idea they do paint the rusty bits on your brake disks though
Posted 01 June 2012 - 02:21 PM
Posted 01 June 2012 - 02:25 PM
Posted 01 June 2012 - 02:27 PM
Vauxhall TECH2 will cycle the ABS for the standard 2-channel ABS controller. You need the Lotus Scan Tool to do the VXR/Exige 4-channel controller.
I did trigger the ABS on mine by a bit of braking on a gravel surface a couple of years back but haven't bothered again since as I've never introduced any air into the system but running the reservoir dry etc.
Yeah, agree with that, i'm always very careful not to empty the reservoir, though during a change of pipes in can all get a bit challenging.
I don't know what the symptoms of air caught in the ABS would be. Its unlikely to be a soft pedal. The only thing i can think ids that it would render less effective braking upon activtion of the ABS.
Posted 02 June 2012 - 12:17 AM
Having seen a post by you on this at some stage I used the same after getting a hard pedal . The hard pedal never returned and I went on to change cylinder,actuator and hoses since. Still can't get the brakes back to where i think they were though. It has me questioning myself whether the percieved difference is in my head or for real. Looks like I will have to try getting them bled using the tech 2 then as next step.
