Jerky Car After Paddle Clutch And Lsd Fitting
10 replies to this topic
#1 Glambee
Glambee
  • 104 posts
Posted 10 June 2012 - 05:01 PM
Just got fitted the Helix 6 paddle clutch and Quaife LSD on my VXT. At the friction point (when the plate is starting to bite the cover), in 1st gear and reverse mainly, the car is a bit jerky. It feels even more juddery when the wheels are fully turned - for example, when starting at a cross road. Is it normal?
#2 CocoPops
CocoPops
  • 17,182 posts
Posted 10 June 2012 - 05:02 PM
Sounds normal from what I'd expect with those mods.
#3 Kieran McC
Kieran McC
  • 3,416 posts
Posted 10 June 2012 - 05:42 PM
try and bleed the clutch again it might help. Mine was the same when first fitted
#4 fiveoclock
fiveoclock
  • 9,453 posts
Posted 10 June 2012 - 08:56 PM
Paddle clutches do this, I havent got one on the VX but I have on the Elise and it judders sometimes in first and all the time in reverse
#5 iVXT
iVXT
  • 680 posts
Posted 10 June 2012 - 09:33 PM
As said above it will be the paddle clutch. Mine does it a bit in reverse which makes you feel a bit of a stump when parking. Your best not to slip a paddle clutch so that doesn't help smoothness either. Re the Quaife. Did you get the rwd ATB diff? I couldn't get one fitted at the same time as the paddle clutch & lightweight flywheel due to time contraints but may be tempted in the future. Where did you get that done? Cheers.
#6 Glambee
Glambee
  • 104 posts
Posted 11 June 2012 - 06:16 AM
Ok, thanks for the answers.
@iVXT: Yes, the RWD, got it at Courtenay:
http://www.courtenay...r/prod_377.html
And fitted in France (I live in Paris).
#7 Nev
Posted 11 June 2012 - 09:20 AM
Sounds a bit unusual to me, I've not had any jerkyness from the 4 different clutch setups I've had.
#8 fiveoclock
fiveoclock
  • 9,453 posts
Posted 11 June 2012 - 10:35 AM
You might not have had it but its a fact some paddle clutches can judder esp in 1st and even more so in rverese.
#9 Bumblebee
Bumblebee
  • 7,592 posts
Posted 11 June 2012 - 11:25 AM
I've got a helix 6 paddle,you just need to put a few more revs on when setting off and this will stop it juddering,not enough revs will cause it judder which is normal IMO
Edited by Aimy, 11 June 2012 - 11:26 AM.
#10 iVXT
iVXT
  • 680 posts
Posted 11 June 2012 - 12:02 PM
Thanks for the info.
Maybe why I only notice it in reverse sometimes. Trying to be a bit more gentle to park or reverse into garage with less revs. As you say if you give a few more revs doesn't seem to do it. No problem though. Small trade off imo.
Cheers.
#11 Bumblebee
Bumblebee
  • 7,592 posts
Posted 11 June 2012 - 01:55 PM
I must say ive been in a lot of cars with 6/4 paddle clutches. and the Vx 6 paddle is far more user friendly IMO just takes a few days to get use to it,just be a bit more aggressive,as i said earlier more revs and try not to slip it too much (although sometimes you have to) and you'll be fine,you'll soon get use to it :)
