An Open Discussion For My Possible Project
Posted 12 June 2012 - 06:47 PM
Posted 12 June 2012 - 06:53 PM
Would love to see it done though.
Love your man maths so much:
I am looking at a total budget of around £15,000.00, maybe more, with my labour being for free and not costed.
The money that my VX has already cost me has in my mind been written off. So I am looking at a £15,000.00 car. Well, there is not a lot out there for that money which is very different.
Posted 12 June 2012 - 07:12 PM
Posted 12 June 2012 - 07:13 PM
Posted 12 June 2012 - 07:17 PM
Posted 12 June 2012 - 07:32 PM
Please.....................merge away thank you.
The AJP is a good engine and as you say.............it is very small.
I even built one up with Jaguar heads, 64 valve jobby. What a performance that was.
But getting bits for it is hard. They are quite fragile and I had hoped to leave TVR behind as an .....almost ....fond memory.
However the single plane crank is a real howler at full "chat". Wonderful.
Techiboy. I thought that you might have had weights and measurements at your finger tips for the Audi motor.
You seem to have so much information....hence Techi....well you get it.
So, has Duncan done this or almost or whatever? Do tell.
Thank you.
SO.........Korkey.
Posted 12 June 2012 - 07:40 PM
Never really been able to find decent measurements and weights for a bare engine, unfortunately. It's probably the only engine that I'd really like to have in the VX. Or maybe the VW R36 V6. They sound glorious as well, when wound up.
There was a vicious rumour that he'd helped out on doing a swap into another VX at one point. Though I'm not sure whether that ever happened as I've not seen/heard any mention of it since. But, I think it's certainly his next VX project after he's sorted out Luke's Audi conversion.
Posted 12 June 2012 - 07:44 PM
Posted 12 June 2012 - 07:54 PM
I had not even thought about the VW R36 V6.
You'll need to go forced induction with it, if you're on the hunt for 400bhp+ though.
Posted 12 June 2012 - 08:00 PM
Posted 12 June 2012 - 08:18 PM
been posted before but what the hell it sounds the dogs...
Posted 12 June 2012 - 08:22 PM
Not sure whether your are looking at a transverse or longditudinal installation, which is the first big question. I'm assuming transverse.
If so, this naturally throws up a number of issues of packaging, primarily related to ancillaries (alternator really), drive shaft position, sump clearance, exhaust routing, boot and engine bulkhead clearance (basically, there isn't enough as far as I can work out - minor mods required!) etc.
Weight wise, the complete RS4 (BNS engine code) is circa 200kg, but removed of ancillaries and non-essential components, weight drops to approx 180kg, which is directly comparable to the standard VXT engine. I don't have completely accurate dimensions of the FSI variants, but the width (as you noted) is pretty big, at ~700mm cam cover - cam cover. Engine height is approximately the same (or slightly less tall than the Z20 engine) and is slightly shorter at ~460mm (crank pulley - bellhousing face). Its actually a very compact engine, just the width, and consequently the packaging of some of the ancillaries that I think may cause the majority of headaches.
I don't know if you've seen this, but should wet your appetite a little:
http://www.youtube.com/watch?v=6pMAxPcQu-Q
http://www.youtube.com/watch?v=bRfMwTlgSn0&feature=relmfu
I also recently spotted this complete engine package for sale
If you haven't already read this, it gives useful information on the engine:
http://www.s4-mtm.co...-StudyGuide.pdf
I've done a couple of desk-top studies on some 6 and 8 cylinder engines that might be go'ers, as I personnally think its the only thing really missing from my VX.
I would also get in contact with Duncanvxr, as he's been up close and personnal with this particular combination, and I believe also has contacts that may be able to help with the engine control side of things, which can get quite complex / expensive due to the FSI fuel injection arrangement. Note that the engine in the above vids has completely done away with this system, and runs traditional port injection, as the FSI is relatively poorly supported by aftermarket engine management it seems.
I still think it is a good option, but definately for someone with the time, space, skills and cash like yourself rather than a plucky spanner wielder like me.!
Ross
Posted 12 June 2012 - 08:42 PM
Edited by techieboy, 12 June 2012 - 08:46 PM.
Posted 12 June 2012 - 09:00 PM
Love how he's kept the RS4 exhausts, complete with valves and just re-orientated them in that first video.
ETA: Christ, the neighbours and noise police are going to love him, in the second vid.
By the looks of it he probably owns all those blocks and houses surround by fields
Posted 12 June 2012 - 09:01 PM
Posted 12 June 2012 - 09:03 PM
Posted 12 June 2012 - 09:22 PM
Posted 12 June 2012 - 09:26 PM
Posted 12 June 2012 - 10:17 PM
Posted 12 June 2012 - 10:27 PM
Edited by Aimy, 12 June 2012 - 10:36 PM.
