Oil Filter Housing Removal / Delete / Relocate Options?
Posted 27 June 2012 - 11:26 PM
Posted 28 June 2012 - 02:02 AM
Posted 28 June 2012 - 07:59 AM
Posted 28 June 2012 - 08:13 AM
Posted 28 June 2012 - 08:18 AM
Posted 28 June 2012 - 09:15 AM
Posted 28 June 2012 - 09:27 AM
Posted 28 June 2012 - 04:14 PM
You can buy the tool from TAT
http://www.tat-dlc.c...king-tools.html
JG? JG? Where are you? You need these in your life and need to sort out a group-buy, sharpish.
Posted 28 June 2012 - 04:23 PM
Posted 28 June 2012 - 04:25 PM
Yes, I replaced both metal gaskets with new ones. Still leaking.
I've never been able to split the cap from the top housing, so it might also be the rubber o-ring at this stage.
Have you nipped the gasket when you did it up? I had the same problem first time I changed mine , I put a replacment gasket on it cured the leak.
Posted 28 June 2012 - 04:27 PM
Posted 28 June 2012 - 04:33 PM
I have a couple of hinged c spanners they worked on mine .Hold in a vice tap it with a nylon punch another option
Posted 28 June 2012 - 04:35 PM
Posted 28 June 2012 - 06:36 PM
It really is easy to feck a new gasket due to the access issues and that they easily move from where they should sit whilst tightening up the cap.
Yes, I did this the first time I changed the oil myself. Spilled out most of the oil during the test drive.
I managed it OK the second time, using new metal seals.
3rd time, it wept a bit, but I couldn't tighten it any more.
I'm going to order the tools, and if that doesn't work, I might try the machine-head route.
Posted 28 June 2012 - 06:49 PM
Posted 28 June 2012 - 07:01 PM
Then coat both sides of the metal seals, finally tighten the filter assembly and job done
Posted 28 June 2012 - 07:02 PM
Agreed, come on JG how come you missed this!
Posted 28 June 2012 - 07:09 PM
Edited by Anarchy, 28 June 2012 - 07:09 PM.
Posted 28 June 2012 - 10:13 PM
