Posted 05 July 2012 - 08:37 AM
Posted 05 July 2012 - 09:16 AM
Posted 05 July 2012 - 09:20 AM
Posted 05 July 2012 - 09:26 AM
Posted 05 July 2012 - 09:46 AM
Posted 05 July 2012 - 09:59 AM
Posted 05 July 2012 - 10:14 AM
They're still a bit fiddly to get started with and require a bit of thought in the design, but there are starting to be some far more user friendly ones that are getting down towards 'sensible' money like: http://technocratica...-challenge.html
The printing material is getting quite cheap too now (~£30/kg). Because the parts are plastic they're only a few grams each, so you actually get quite a lot for your money.
If you're interested in the kind of things you can make, see here: http://www.thingiverse.com/ It's a website where people just post up free designs for 3D objects,
Posted 05 July 2012 - 10:17 AM
Posted 05 July 2012 - 10:18 AM
Posted 05 July 2012 - 10:19 AM
Posted 05 July 2012 - 10:29 AM
Theoretically, you could almost print you own printer..!
That's what http://www.reprap.org/wiki/RepRap does. To be honest the SumPod, milled out of thick bits of MDF, feels a lot more solid though!
The CAD side doesn't seem too bad if you don't want anything serious - try www.tinkercad.com
I imagine complex curves would be difficult, but I've been using OpenSCAD for brackets and stuff and have found it quite easy.
slindborg, yeah, it's not super-strong, but then if you print at the same thickness it doesn't seem a whole lot worse than moulded plastic stuff. I wouldn't print my wheels out of it, but I think for a lot of things it would be more than good enough. It feels significantly stronger than the clam shells are for the same thickness!
edit: actually SLA uses a resin doesn't it? I guess that would be more brittle. Nicer prints though.
Edited by rabidh, 05 July 2012 - 10:31 AM.
Posted 05 July 2012 - 10:44 AM
Posted 05 July 2012 - 10:53 AM
Posted 05 July 2012 - 11:04 AM
Posted 05 July 2012 - 11:06 AM
Posted 05 July 2012 - 11:07 AM
Edited by Aimy, 05 July 2012 - 11:11 AM.
Posted 05 July 2012 - 11:36 AM
SLA is usually resin, so it is a shade more brittle.
We've had some plastic prints and they aren't that much 'better' but they don't shatter if you look at them funny
Made lots of interior panels with the printing for various little projects.
Posted 05 July 2012 - 12:28 PM
I use a lot of 3D prototyping at work and is very specialist art, choice of resin build time, build orientation and machine choice all contribute to the strength and durability of the parts.
Unless using state of the art machines and materials there is not much that you could make that would be 'bolt on' as most plastic and metal parts at lower price points are very brittle as people have already mentioned, also they degrade in heat and UV very quickly.
This would be really good for making the forms or bucks for molded parts maybe you could make things like the mirror and get somebody like jonnyboy or Scottybob (ultimate Carbon) to mold them.
Good luck, look forward to seeing the results!
Posted 05 July 2012 - 12:47 PM
Posted 05 July 2012 - 02:05 PM
