6 Point Harness Mounting
Posted 10 July 2012 - 11:50 AM
I'm having no luck with Lotus dealers. They want to sell me a 6-point harness for £375.56 and can't tell me if the fitting kit is included or not.
Has anyone used this setup or something similar?
Posted 10 July 2012 - 12:31 PM
Edited by Nev, 10 July 2012 - 12:31 PM.
Posted 10 July 2012 - 12:40 PM
Posted 10 July 2012 - 03:53 PM
Posted 10 July 2012 - 04:11 PM
Edited by kieranmcc, 10 July 2012 - 04:13 PM.
Posted 10 July 2012 - 05:48 PM
Posted 11 July 2012 - 08:25 AM
The MSAR pack looks great for the crotch strap - thanks :-)
Anyone use eye bolts for the lap belts? Are there any other solutions for mounting the lap belts to the chassis?
Mine mount to the seat subframe and I use spreader plates for the crutch strap.
Having spoken to Malcolm at MSAR and heard his opinion on the fitting kit, I decided against it.
Posted 11 July 2012 - 09:07 AM
Posted 11 July 2012 - 09:27 AM
I want a fifth strap but i have no room under my seat as it's seat is set very low. Do the eye bolts for crotch straps go through the floor only coupled with a spreader plate, or through the cross member?
The eye bolts in the 2-11 setup are used for the lap belts.
The crutch strap is attached to the forward bar which is bolted to the floor using spreader plates and to the crossmember.
Posted 11 July 2012 - 09:31 AM
Are you using the standard seat frame?
Will this method pass MSA strutineering?
Posted 11 July 2012 - 09:42 AM
Ah ok. My lap belts are bolt through not eyelets, hence being bolted to the seat frame. I'm not using a standard seat or seat bracket (tillett b5 and fixed tillett seat mount). Guess i'll need to find an alternative way as there isn't a lot of room under my seat.
