How Much Pressure To Use In The Gunson Eezibleed?
17 replies to this topic
#1 hughcam
hughcam
  • 730 posts
  • Interests:driving, motorcycling, snowboarding, v12 lawn mowers
Posted 16 July 2012 - 03:35 PM
I attempted to use the Gunson Eezibleeder with 20 psi of tyre pressure and made a massive mess. Is this too much? (The instructions say to use 20 psi)
#2 JG
JG
  • 13,613 posts
Posted 16 July 2012 - 03:38 PM
Yep, 10 is about all you want. the servos don;t like a lot more than too.
#3 hughcam
hughcam
  • 730 posts
Posted 16 July 2012 - 03:39 PM
Will give it a go with 10 psi. Cheers JG thumbsup
#4 siztenboots
Posted 16 July 2012 - 03:41 PM
isn't it something crazy high in the brake lines themselves due to the pedal ratio , 700psi
#5 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 16 July 2012 - 03:50 PM
I found ezibleeder a complete load of confusing bollox when I tried one. I just did the normal method. Nowt wrong with that.
#6 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 16 July 2012 - 04:09 PM
im having fun with air in the system.... never ending fun fun fun A very good link http://wiki.seloc.or...ing_brake_hoses
Edited by mbes2, 16 July 2012 - 04:10 PM.
#7 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 16 July 2012 - 04:11 PM
when me and boombang did mine in March we used a pipe connected to a spare wheel he had about and went about one wheel at a time, I stood at the front and just took the cap with the tube in off to refill the reservoir when it got about half empty and then reconnected the wheel connected cap till we were all done.. Dont forget the clutch :) really easy system, No idea what it was called but worked a treet.
#8 slindborg
Posted 16 July 2012 - 04:12 PM
if only some doodah wrote a guide on how to use one........
#9 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 16 July 2012 - 04:17 PM
http://www.vx220.org...eed-the-brakes/
thumbsup
#10 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 16 July 2012 - 04:35 PM
Yes actually watching that guide we kinda got the wrong end of the stick I think :lol:
#11 MrSimba
MrSimba
  • 5,197 posts
Posted 16 July 2012 - 08:18 PM
As JG said 10psi is fine :)
#12 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 17 July 2012 - 06:50 AM
After fitting goodridge brake lines I ended up having to invert my front calipers then bled them, this worked, as per the wiki guide.... plus, on the test drive.... coming straight of gas to brake didn't cause the hard brake pedal problem.... which is a first... It was either luck as I cant see how new hoses would stop this.... more testing the weekend.
#13 Pidgeon
Pidgeon
  • 5,254 posts
Posted 17 July 2012 - 07:49 AM
I put mine on the nearest wheel, so it will hold 30+ psi
#14 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 17 July 2012 - 07:55 AM
Same here. As a rule, always do a quick pressure test run without any fluid in the Gunson reservoir to see if there are any air leaks - better than spraying brake fluid everywhere! This way you can sort any potential leaks out and know how tight to do up the connections :)
Edited by starlight, 17 July 2012 - 07:55 AM.
#15 Boombang
Boombang
    Saxo boy
  • 3,022 posts
Posted 17 July 2012 - 08:55 AM
20psi here but the trick is to not put any fluid in the EZ-bleed bottle. That just ends in disaster. Instead before the fluid goes below minimum top it right up and bleed through. This is where Stu's idea of using cheapo fluid to flush through is best (Halfords dot 4 on trade works for me). With the VX you need the fluid to be right at the top to bleed the clutch as the take off is way up on the brake fluid reservoir, for obvious reasons. Best done in a few attempts, topping up each time.
#16 slindborg
Posted 17 July 2012 - 11:11 AM
I always fill the bottle, with a fcuk load of fluid. Then run on 10psi or less.... never had an issue. When I tried 20psi it was a messy messy day :lol:
#17 chris_uk
Posted 17 July 2012 - 11:14 AM
I put 18psi through it. It was what was left in a spare wheel i had.
#18 hughcam
hughcam
  • 730 posts
Posted 17 July 2012 - 11:47 AM
Cheers for the assistance lads - I should have read Slidborgs guide lol :sleep:
