Hi
I have just been adjusting my windows and have over-screwed (is that a word???) the grub screw for the window. The grub screw has now fallen inside the door. Is there an easy retrieval method or did I read somewhere that the door needs taking off to get the little bu**er out again?
Why did Vauxhall not put a head on this bolt? Would make it easier for people like me when we f**k up.
Many thanks
Mike
Buggar ... Need Some Help..
Started by
Mike9009
, Jul 12 2004 04:47 PM
3 replies to this topic
Posted 12 July 2004 - 04:47 PM
Posted 12 July 2004 - 07:14 PM
Please excuse the pun but...you're screwed!!!
There is no easy way to retrieve, its a dismantle job!
Posted 13 July 2004 - 07:53 AM
In the words of the great homer simpson "DOH!"
Sorry about this. Get a copy of the Vauxhall (TIS?) CD off here or Ebay and get the door striped. It's probably just a case of getting the trim off the inside. Tighten everything up while you're in there!
Posted 13 July 2004 - 09:02 AM
remove the trim, easy if you have minimal diy skills, two screws to be removed, then the window winder (5 small allen bolts) and then you remove the panels, first the small one in the back, , then the bigger one, carefully ripping it off its pressure mounts.
you might want the screw to roll backward inside the door first....
