Posted 04 August 2012 - 09:03 PM
Posted 04 August 2012 - 09:12 PM
Posted 04 August 2012 - 09:15 PM
Posted 04 August 2012 - 09:21 PM
Posted 04 August 2012 - 09:22 PM
This possible on a turbo?!having an NA means I have it programmed to switch the fan on and off when I want,
Posted 04 August 2012 - 09:40 PM
Thanks for the info mr simba
Does the scangauge do data logging that you can print graphs out etc?
I've currently got a digital afr gauge and a boost gauge so i guess thats 1 thing not to worry about.
Also Does the scangauge read oil pressure?
Edited by MrSimba, 04 August 2012 - 09:41 PM.
Posted 04 August 2012 - 09:45 PM
Posted 04 August 2012 - 09:47 PM
I'm afraid I don't think it is. It's down to the different ECU used on the 2.2 I think, I used the info off of Mark Verbooms page: http://www.verboom.n...1016/index.html
Posted 05 August 2012 - 07:54 AM
That looks reminiscent of the cockpit from a fighter jet
Posted 05 August 2012 - 12:08 PM
Posted 05 August 2012 - 12:20 PM
Posted 05 August 2012 - 12:42 PM
What are you trying to achieve?
Boost and lambda gauges in the cabin are good guides as to what's goin on. Scangauge is ideal for more info and mil resets but not that user friendly. And the diagnostics method (eg opcom or think geek thing) would be most info but irritating to use on a day to day basis.
Posted 05 August 2012 - 01:08 PM
Bad times
Posted 05 August 2012 - 01:38 PM
Posted 05 August 2012 - 01:50 PM
Bluetooth obdii reader and the 'Torque' app. Total cost 20 and you can monitor and datalog to your hearts content. There are a few of us with this system.
Edited by Aimy, 05 August 2012 - 01:54 PM.
Posted 05 August 2012 - 02:03 PM
Posted 05 August 2012 - 02:09 PM
Posted 05 August 2012 - 09:16 PM
Posted 06 August 2012 - 02:34 PM
Posted 06 August 2012 - 03:36 PM
Is anyone using one of these?
http://www.aim-tec.c...chron3.htm.html
Should be one of the easiest ways to achieve all the logging one may need?
//Johan
