Laminova's Bone Dry Or Wet And Gritty....?
Posted 05 August 2012 - 06:41 PM
I was expecting the fins to be dry and dusty so to speak...... So what's normal...?
Posted 05 August 2012 - 06:45 PM
Posted 05 August 2012 - 06:49 PM
Posted 05 August 2012 - 06:54 PM
Edited by vocky, 05 August 2012 - 06:54 PM.
Posted 05 August 2012 - 07:09 PM
Posted 05 August 2012 - 07:10 PM
Posted 05 August 2012 - 07:49 PM
http://parts.nalleyg...assembly=364352
http://gmoem.com/oem...s/12584356.html
Posted 05 August 2012 - 08:03 PM
Posted 05 August 2012 - 08:06 PM
OMG!!! Am I being dull here or are these o rings $25 each!!!
http://parts.nalleyg...key_assembly=364352
Eek
I'd measure the ones you have and buy an aftermarket part. There's no way a rubber o ring should cost that much
Posted 05 August 2012 - 08:07 PM
Posted 05 August 2012 - 08:23 PM
Posted 05 August 2012 - 08:27 PM
Get the sizes/shore/material and I will see how much I can get them for......I work for a company who design/build valves for extreme conditions and as part of this we often specify "exotic" o-rings, it may be that to get the costs down I have to order enough for a few people (mini group buy type of thing) but there are enough people on here with s/c'd cars that it would cover it.
I would happily take a set for future use as well.
Posted 05 August 2012 - 08:34 PM
Me too. Add to my treasure trove of 'what if' parts
Posted 05 August 2012 - 08:50 PM
Posted 05 August 2012 - 09:04 PM
Posted 05 August 2012 - 09:21 PM
Ok will do... .To clarify.... in normal operation the exterior fins of the laminovas should remain dry?
In normal operation these should stay clean and dry. But depending on your crank vent routing, your air filter layout and also the charcoal vent system (I got some blck coal dust from this one) they will grab dirt. Yours are pretty gross!!
Posted 05 August 2012 - 10:33 PM
Eek
Sutol found these
O rings size 29.75 x 3.53 nitrile BS217
http://supaseal.co.uk/kits.htm#o-rings
Posted 06 August 2012 - 06:59 AM
It's the level of moisture that troubles me most!!! The outside of the fins were moist which caused all the dirt to grain up like that! I'm getting a mysterious missfire with the car and thinking maybe coolant in the head may cause it.... Just hope I've not bent any more valves!!
Posted 06 August 2012 - 07:49 AM
Posted 06 August 2012 - 08:22 AM
it's possible that on full boost the engine was sucking in cc coolant (past the leaky seals) and that might have caused a misfireIt's the level of moisture that troubles me most!!! The outside of the fins were moist which caused all the dirt to grain up like that! I'm getting a mysterious missfire with the car and thinking maybe coolant in the head may cause it....
