just ordinary O ring seals, nothing specialSutol found these
O rings size 29.75 x 3.53 nitrile BS217
http://supaseal.co.uk/kits.htm#o-rings
Laminova's Bone Dry Or Wet And Gritty....?
#21
Posted 06 August 2012 - 08:24 AM
#22
Posted 06 August 2012 - 10:05 AM
Mine has had a few types of filter on over the years and this is the first time the cores have been out (since install), so I don't know which filter was the worst. I have an apexi cone now but think the one cliffie has might be worth a try that or a modded oem box
Edited by NickB777, 06 August 2012 - 10:14 AM.
#23
Posted 06 August 2012 - 10:07 AM
#24
Posted 06 August 2012 - 10:52 AM
#25
Posted 06 August 2012 - 11:57 AM
#26
Posted 06 August 2012 - 02:20 PM
Also, aside from fouling your laminovas, imagine the damage to the piston rings and bores that all that grit is doing.
Lastly once that dirt/grit has managed to pass your rings, it will drop into the sump and contaminate your oil which in turn will increase wear rates on virtually every other component in the engine
*cough* oil filter
#27
Posted 06 August 2012 - 02:45 PM
#28
Posted 06 August 2012 - 03:27 PM
Edited by VXed, 06 August 2012 - 03:38 PM.
#29
Posted 06 August 2012 - 03:28 PM
Shows virtually no point in changing the air filteras the biggest gain was 0.14% at the expense of letting in more particles....
#31
Posted 06 August 2012 - 03:40 PM
http://www.mkiv.com/...filters_test/2/
mmmmmmm shite.
No Good Slingborg?
I saw that and it was one of the reasons I went Apexi I had a pipercxross and before that K&N
Edited by NickB777, 06 August 2012 - 03:42 PM.
#32
Posted 06 August 2012 - 05:53 PM
Edited by Nev, 06 August 2012 - 05:53 PM.
#34
Posted 06 August 2012 - 07:25 PM
#35
Posted 06 August 2012 - 07:36 PM
I would have guessed stainless but they are magnetic.
I'm pretty sure the cheaper SS grades can become magnetic...
#36
Posted 06 August 2012 - 07:42 PM
Cheap 304 st/st is magnetic.....not great for washers either.
#37
Posted 06 August 2012 - 07:49 PM
#38
Posted 06 August 2012 - 08:00 PM
mmmmmmm shite.
No Good Slingborg?
Oem paper or just pour sand into the engine.
#39
Posted 06 August 2012 - 08:25 PM
